Old 10-07-2012, 11:04 PM   #11
Herk7769's Avatar
Originally Posted by taxbuster View Post
I've been trying to pull mine (but discovered that the size socket that I had was 1/16" too small....sigh).
But I have a question -- mine looks like it has a small screw on the centre of it -- what is that about?
Also, tried to loosen the thing with a wrench/vise grip but no joy. Shouldn't it be just a little tight and not jammed right on?
Thanks - a mystified Canuck where it's going to get really cold, really soon....
OK, Advice from my father: "never use vice grips on something you don't want to throw away if it does not work out"
A photo of the anode would help. If you have an Atwood water Heater it may just be a drain plug and not an anode.
HAM CALLSIGN - KC3FFW
Old 10-08-2012, 01:12 PM   #12
Finally borrowed a 1 1/16" socket, found an adapter from 3/8" > 1/2" for the socket, and still had to use a length of pipe over the socket handle to get enough leverage to undo the anode. (Too true, the vise grips were useless.)
...and, of course, I got soaked.
Oh well, lesson learned!!
taxbuster is offline   Reply With Quote
Old 10-10-2012, 02:12 PM   #13
ret2006's Avatar
I have a 12 gallon Suburban water heater. Going to buy an anode rod and see that there is an aluminum and a magnesium rod.
Can't find anything that says to use one or the other.
Which one should I get?
2014 Cedar Creek 34 RLSA-7
2015 Chevy Silverado 3500HD LTZ SRW
ret2006 is offline   Reply With Quote
Old 10-10-2012, 03:00 PM   #14
Herk7769's Avatar
Magnesium is more reactive than aluminum, but both protect the iron in your boiler very well. The magnesium rod won't last as long.
(If you file it into tiny pieces and toss a match in it; it is very cool though!)
Old 10-10-2012, 03:59 PM   #15
B47
Not only by filing it into tiny pieces and starting a fire, but if you can ever a video of a large aircraft wheel (s) catching fire from an overheated brake, you will see a large fire.
Old 10-10-2012, 07:28 PM   #16
Herk7769's Avatar
"Missed it by That Much"
My Class C mishap - blown tire on landing.
Name:	Martinsburg Class C Tire Failure.jpg
ID:	20514   Click image for larger version
Name:	On the runway color.jpg
Old 10-10-2012, 07:56 PM   #17
Trailer Trash
Originally Posted by ret2006 View Post
I have a 12 gallon Suburban water heater. Going to buy an anode rod and see that there is an aluminum and a magnesium rod. Can't find anything that says to use one or the other. Which one should I get?
Magnesium is plan A. Aluminum is plan B. Read why here.
Anode Rod, Magnesium or Aluminum ? [Archive] - Heartland Owners Forum
Ya I know I just dropped the Fbomb with that Heartland link. But in the spirit of helping our fellow Forest River owners out......I just had to do it.
joelek is offline   Reply With Quote
Old 10-10-2012, 08:12 PM   #18
j2detroit's Avatar
I pull mine at the end of the season every year when I drain and flush clean the rod up a little the reuse next season we usually get 3-4 seasons out of it and then I just put in a new one
j2detroit is offline   Reply With Quote
Old 10-10-2012, 08:38 PM   #19
Mark and Linda's Avatar
RT. Rear near the SPR panel...? Was the manifold drained?
2009 Palomino Puma 25RS
2007 Chevrolet Silverado
Prodigy P2 Brake Controller
Mark and Linda is offline   Reply With Quote
Old 10-10-2012, 08:42 PM   #20
B47
Yepp - that is what happens when mag wheels caught fire.
Glad you were not hurt - crew members OK also?
anode
