Old 10-08-2016, 10:14 AM   #11
wmtire's Avatar
Originally Posted by DisDad01 View Post
Ok well it tried to push the reset buttons last night and it didn't work. Tried again this morning and still nothing. The cover for the buttons is really hard but I think I'm hitting the buttons. Any other ideas?
2012 Ford F-150 EB Crew FX4 3.73 gears
2012 Micro Lite 23lb
A lot of times if you burn out the element, it also burns out the fusible link between the hi-limit and the thermostat.....so no power is reaching the element if this happens.
You can take off the rubber cover over the reset buttons to the ECO hi-limit/thermostats to check for power at that point. It's also let you know if your black switch is operating if you have 120 volts on one side of the ECO/Thermostat.
You can visually see if the fusible link is burned out, like it is in this pic. Notice how it's burned out on the left ECO/Thermostat (which is the one to the electric element). The right one goes to the 12 volt propane side.
This fusible link is the little thin wire between the top and bottom.
2011 Flagstaff 831 RLBSS
Yayy !!! I Won employee of the month again....I just love being self employed.
Old 10-08-2016, 10:14 AM   #12
northstar1960's Avatar
Get your volt meter out and start eliminating possible issues . are you sure you have 120v do you have 120 at the thermostats ? do you have 120 at the element ? etc
northstar1960 is offline   Reply With Quote
Old 10-08-2016, 10:15 AM   #13
bubbles's Avatar
Pull the cover off (2 screws) and check that the fuseable link between the thermostats has not melted.
Old 10-08-2016, 10:28 AM   #14
wmtire's Avatar
I have to ask again, are you positive you have water in the tank?
Have you flipped up the lever on the temp/pressure relief valve to verify there is water in the tank?
Do you have hot water using propane for sure too. I'm trying to also verify you don't have the bypass valves incorrect....which is common as per the link below
NO (OR MINIMAL) HOT WATER (Please read first)
Old 10-08-2016, 10:41 AM   #15
At this point, if it were me, I'd remove the resets and the switch and check their continuity individually.
1988 Coleman Sequoia - popup (1987-2009)
2012 Roo19 - hybid (2012-2015)
2011 Traverse LT, 3.6L, FWD
2009 Silverado Ext Cab, 5.3L, 4x4, 3.73
rockfordroo is online now   Reply With Quote
Old 10-08-2016, 11:00 AM   #16
bubbles's Avatar
Why remove them? Just check for 115 volts at each wire terminal. 115 volts in/115volts out.
Old 10-08-2016, 11:22 AM   #17
Figured he'd already tried that.
Old 10-08-2016, 11:43 AM   #18
bubbles's Avatar
Well, if there's volts on one terminal and not on the other and the reset has no effect or can't be done the thermostat is bad. Just change it.
Old 10-08-2016, 01:34 PM   #19
PSUFan1's Avatar
Well the second screw holding the reset button cover is blocked by what appears to be the gas line coming in.
Name:	ImageUploadedByForest River Forums1475948068.287069.jpg
Tim & Tracy, Jennifer (15), Alyssa (10), our dog Jazy
2012 Ford F150 EB Crew FX4 3.73 gears
2017 Grand Design Imagine 2800BH
Previous: 2012 Flagstaff MicroLite 23LB
2006 GMC Envoy Denali V8 & 2005 GMC Envoy I6
PSUFan1 is offline   Reply With Quote
Old 10-08-2016, 01:37 PM   #20
PSUFan1's Avatar
Yes there is water in the tank. I'm currently running the propane to heat the hot water.
electric, hot water, suburban, water, heater
