Old 10-10-2016, 04:06 PM   #31
We have a 23LB also and are having the same problem with the water heater working on propane but not electric. We haven't had time to look into it yet so we have been running it on propane the past 2 camping trips. DH thinks its the element but after reading this post, I'm wondering if that's what the problem is or something else.
2011 MicroLite 23LB
2012 Ram 1500 Crew Cab
zinger60 is offline   Reply With Quote
Old 10-13-2016, 08:22 PM   #32
Don't forget to check the breaker inside the electric distribution box/converter. Mine has a breaker specifically for the water heater element.
ProfChuck is offline   Reply With Quote
Old 10-15-2016, 07:36 AM   #33
Hot Water tank
The problem was a burnt wire on the rear of the on and off switch at the tank. Used a jumper wire to make the connection and water heated again.
Replaced the switch all is heating with electric again.
Many thanks
bumby
Bumby is offline   Reply With Quote
electric, hot water, suburban, water, heater
