Old 10-07-2016, 05:30 PM   #1
PSUFan1's Avatar
Suburban hot water heater not working on electric
I welcome any ideas. I just replaced the element and it's still not working. I don't see any fixes blown. Click image for larger version
Name:	ImageUploadedByForest River Forums1475875797.780310.jpg
2012 Ford F-150 EB Crew FX4 3.73 gears
2012 Micro Lite 23lb
Tim & Tracy, Jennifer (15), Alyssa (10), our dog Jazy
2012 Ford F150 EB Crew FX4 3.73 gears
2017 Grand Design Imagine 2800BH
Previous: 2012 Flagstaff MicroLite 23LB
2006 GMC Envoy Denali V8 & 2005 GMC Envoy I6
PSUFan1 is offline   Reply With Quote
Old 10-07-2016, 05:40 PM   #2
brookstone345sa's Avatar
The two black buttons in your photo are resets. Try pressing on them. Make sure your outside electric switch is
brookstone345sa is offline   Reply With Quote
Old 10-07-2016, 05:44 PM   #3
wmtire's Avatar
Make sure there is water in the heater before doing anything. Flip up the lever on the temp/pressure relief valve at the top to make sure. You turn on the heating element with no water in the tank, and you just burned up your new element.
1. Has it worked on electric before.
2. Are you plugged into an 120 volt power source and/or is the water heater plugged into an outlet (on the backside) and is the circuit breaker turned on that controls the water heater (120 volt AC stuff has circuit breakers, 12 volt DC has fuses)
3. Is the electric switch in the bottom right hand corner turned on
4. Have you checked the ECO hi limit/thermostat behind the rubber cover to see if it is tripped or burned out? have you pushed the reset button on the left thermostat?
I know this sounds weird, but are you sure you replaced the element and not the anode rod. I have a reason for asking such.
2011 Flagstaff 831 RLBSS
Yayy !!! I Won employee of the month again....I just love being self employed.
Old 10-07-2016, 05:47 PM   #4
PSUFan1's Avatar
Should switch be on or off when I press reset
Old 10-07-2016, 05:48 PM   #5
PSUFan1's Avatar
Yes it's worked before
Yes I'm hooked up to electric
Old 10-07-2016, 06:11 PM   #6
Flybob's Avatar
Doesn't matter. If you feel either one snap when you push it, it was tripped. They are snap discs.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 10-07-2016, 06:14 PM   #7
BTW: In item #3, wmtire meant "Is the electric switch in the bottom LEFT hand corner turned on?" (It's behind that coil in the gas line in his pic.)
1988 Coleman Sequoia - popup (1987-2009)
2012 Roo19 - hybid (2012-2015)
2011 Traverse LT, 3.6L, FWD
2009 Silverado Ext Cab, 5.3L, 4x4, 3.73
rockfordroo is online now   Reply With Quote
Old 10-07-2016, 06:47 PM   #8
PSUFan1's Avatar
Yep turned on
I've pressed the reset buttons so time will tell if it worked.
Old 10-07-2016, 07:02 PM   #9
wmtire's Avatar
Yep, left hand corner. Thanks.
I was on the computer, so can't blame that one on autocorrect. Lol
Old 10-08-2016, 10:06 AM   #10
PSUFan1's Avatar
Ok well it tried to push the reset buttons last night and it didn't work. Tried again this morning and still nothing. The cover for the buttons is really hard but I think I'm hitting the buttons. Any other ideas?
electric, hot water, suburban, water, heater
