Old 03-11-2015, 01:15 PM   #1
Question Suburban hot water tank - on/off switch
The tank was full of water and we were using hydro to heat the water. The other day, there was no hot water. The breakers were not tripped. The outside switch was still in the on position. I tried switching it off, but the switch is stuck and will not move to the off position. I have used this switch before when storing the RV. The propane function still works.
Does anyone know what might be happening? And how to remedy this situation?
Callander is offline   Reply With Quote
Old 03-11-2015, 01:26 PM   #2
wmtire's Avatar
The switch may have just burned up. They are known to go bad, especially when they aren't turned off/on regularly.
I carry a spare one of these, but have never needed it yet. If you have a local RV store, they usually have them in stock for less than $10.
http://www.amazon.com/Suburban-23225.../dp/B00C5RAU9W
2011 Flagstaff 831 RLBSS
Old 03-11-2015, 01:29 PM   #3
Could also be the 120v hi limit is tripped or burnt out.
Old 03-11-2015, 01:34 PM   #4
wmtire's Avatar
This is also true, but I wouldn't think that should have any bearing on the switch being stuck, and not being able to turn off.
Old 03-11-2015, 01:42 PM   #5
True, but it would explain why there is no hot water when on 120v, which was her first statement.
Old 03-12-2015, 11:54 AM   #6
Send a message via AIM to jk31668
Mine was the elect element had burned out. Easy to replace
jk31668 is offline   Reply With Quote
Old 03-12-2015, 01:56 PM   #7
Check the switch with a meter or continuity checker to se if the switch is bad before anything else.
FOREST RIVER FW 8524RLWS
2010 FORD F 150 5.4
#1-18' Nomad #2- 20' Mallard #3- 27' Sunline #4- Four Winds C #5- Innsbruck 40' PARK # 6- 28' Amerilite #7- Forest River 26.5 FW ( 1st FW)
SULTINI is offline   Reply With Quote
Old 03-12-2015, 04:17 PM   #8
Kanadian Kamper
kenandterry's Avatar
Yup.....I had my switch go belly up. They're cheap little plastic switches and sometimes it happens. They're easy enough to pop out of the panel and measure to see if you've got voltage coming in and going out. You might want to turn off the breaker inside the coach as you test for 110V voltage, or it could be shocking.
I also had the hi limit go belly up, but the switch not being able to move would make it my first choice to troubleshoot.
Ken and Terry
kenandterry is offline   Reply With Quote
hot water, suburban, tank, water, water tank
