Trailer is a 2018 FR Stealth TSG2910. Purchased in August of 2017 with a 7 year warranty. I took it out camping a handful of times from Sept thru Oct 2017 and then moved into it full time in Nov 2017.
I've done some searching and reading here and found what I believe is my first issue. I'll know in the morning when I have time to pull things apart.
First issue: My propane ignitor is intermittent. It started in May and has gotten worse as time progresses. As indicated in the linked threads below, the propane valve will open with an audible "clunk" but will not be preceded by the "tick, tick, tick, tick" of the ignitor. It will cycle 3 times and the DSI FAULT light will light on the master switch panel. If I cycle the WH switch in the panel it will usually come on. I have also tried giving the control box a tap (it's easily accessible under the kitchen sink) while the WH is going thru it's cycles to light and it will work. I grow concerned because today as I was doing dishes I heard and felt a loud WHOOMP as it lit, like propane was supplied before the ignitor hit and when it did it lit a large excess of gas. I actually went outside to make sure the cover hadn't been blown off the side of the trailer and there was a definite smell of propane in the air.
These 2 threads are very helpful if you're having ignitor issues:
http://www.forestriverforums.com/for...-138845-2.html
http://www.forestriverforums.com/for...ml#post1559917
Second issue: I originally thought I had a 6 gallon unit because I can run out of hot water in 1 shower or when doing dishes from dinner. I take "combat showers" so the water does not run the entire time I'm in and there's no way I use a total of 10 gallons of water while I'm in there for 6 minutes or so. The water is good and hot until it is not. I can hear the propane kick on (given it's working properly) but it doesn't keep up with the demand and takes a while to get back up to a decent temp.
So, what gives? I think 10 gallons of hot water mixed with cold water should be more than sufficient to take 1 shower or do 1 round of dinner dishes. Has anyone else had this issue? Were you able to fix it? How did you fix it?
Notes: All the valves are lined up correctly (bypass is shut), neither of the thermostat trips have ever tripped and I've tried the WH on both propane and electric with the same results.
I've been kicking around the idea of getting an on demand unit but have much more reading to do on that subject. It seems there are plenty of issues with those as well and I want to make sure it's the right decision before pulling the trigger. I am looking at living in my trailer for another year while I buy land and build my wife the house of her dreams.
