Old 10-25-2011, 07:19 AM   #1
Roswell-N-Marcia's Avatar
Angry Suburban SW6DE Hot Water Heater
Okay - I'm stumped. No ignition (no gas). Tube - clean/cleared. No blown fuses. Checked the LP Gas Valve (turned "on" heater switch, ignitor clicked with spark and nothing). Checked electrical the four connectors - each had power when the ignition system was in progress. Had resistance across poles 3&4 - but not 1&2....new valve time? Oh - electrical heating element worked perfectly.
Roswell-N-Marcia is offline   Reply With Quote
Old 10-25-2011, 07:38 AM   #2
TURBS's Avatar
Sounds like gas valve may not be opening.
can you get a wif of gas at all?
assuming your not out of gas and there's no air in the lines
Old 10-25-2011, 01:19 PM   #3
No whiff of gas. The heater, stove, oven and refrigerator all work...perfectly. I "cracked" the line opening into the valve with a soap mixture - bubbled dramatically with a STRONG smell of gas. My conclusion is that it's not opening.....so, it's probably time to replace the valve....unless you know a fix. To top it off.....I've owned the trailer 2 years and 2 months (new) - you can probably guess the dealer's response.
