01-11-2014, 08:03 PM
Suburban SW6DE water heater Boo Boo
Just before we left to come to FL, I decided to check/clean or replace the anode in the water heater. Always having used both electric and propane mode together, I just turned off the propane, drained the tank, removed the anode, bead blasted it and re-installed it, filled the tank and forgot about it. A few days ago, I needed to refill a propane tank, so I shut the propane off and while TOWTA was doing dishes, etc, I had the tank refilled. Came back and TOWTA said we're out of hot water. I checked the water heater breaker inside, good, checked to make sure the switch was on outside and it was and then the light came on (very dimly). Hey dumb a-- you burned the element up when you drained the tank and didn't unhook from shore power. OK, down to Camping connection to buy a new element. Bought 2 just in case I had another brain f-rt. Installed, works fine. Later, we're out of hot water. Check breaker inside, good. check reset outside and it's tripped. Reset and good to go. Again out of hot water, outside reset tripped again. Back to Camping Connection and get a new thermostat. $37 later and about 30 minutes work and all is well. Lesson learned, brain f-rt cost a total of around $50 and about 1-1/2 work. Time I could of spent reading.
01-11-2014, 08:32 PM
Damn, I hate it when that happens, Coot.
How are you guys doing? Say hello to your bride from us.
Mike
Mike and Yvonne
and Sophie, the little white dog
2017 Columbus 320RSC
2021 Chevy Silverado 3500HD DRW 4X4 Duramax
“It's not how old you are, it's how you are old.” ― Jules Renard
"It's not the years...it's the mileage." - Indiana Jones
01-11-2014, 08:38 PM
Mike
Me too, just dumb on my part, so now when we get home, I'll try to remember to turn it off at the heater.
We're having a good time enjoying the weather (all but 2 cold days). Can't beat the weather here in FL in the winter. Hope MO weather is getting better.
01-11-2014, 08:48 PM
I also burned out the element in our previous TT. Luckily no issues with t-stat. The most difficult part of the job was loosening it. The tool I bought to remove the element did not stick out quite far enough to get a good turn on it.
Of all the stupid human tricks we can do around our rigs this one doesn't usually cost too much.
We came back from FL on Dec 30 so you are officially making me jealous..
2015 F-350 SRW 6.7 PSD
2014 Crusader 295RST
1 Fantastic DW
1 Amazing DD
1 Beagle that will be missed (RIP Zeus)
01-11-2014, 09:03 PM
I bought the tool also, when I get home I plan on welding a top on it and an old socket for a 1/2" ratchet to make it easier to use. I always carry my 1/2" torque wrench to check the lug nuts, anode and pin box pivot nut.
01-11-2014, 10:55 PM
Good idea OC. I was thinking of doing something similar with mine. It was bloody cold when I replaced the busted element (during our winter camping season) and I ended up using a long screwdriver that I bent and I smacked with a blunt object to get it loose. It did work, but I don't want to repeat it.
1 Fantastic DW
1 Amazing DD
01-11-2014, 11:41 PM
Thanks for sharing OC.
01-12-2014, 12:48 AM
Why bead blast an anode rod? Wouldn't letting it soak in a container of white vinegar work? That is what I have been doing to my after-market anode rod. Within a short period of time the clear vinegar turns into a gray colored liquid and the anode rod is clean. My new TT is still winterized and have had no experience with the Suburban brand yet.
Bob
2013 Ford F250 SD 6.7L
2014 Wildwood Heritage Glen 282RK
Certified Rumble Strip Tester
01-12-2014, 10:15 AM
NELA
Hmmm, for some reason I imagined that you brought your welding rig with ya OC. Or at least rented one for your stay there or made quick friends with someone local that has a rig.
A DIYer like you must feel kinda lost without one.
(BTW, your name was mentioned *often* yesterday while DH loaded and organized the pass through on our new toy...referencing that great sliding rack you made for yours)
If age is a state of mind, and I've lost my mind, I'm AGELESS, right?
Give me 40 acres and I'll turn this rig around:
Flagstaff 5er 2014 8528 IKWS, Platinum Package, Regency Interior "Buffy"
F250 Super Duty 2013 Tuxedo Black "Biff"
Days camped 2014: 30
01-12-2014, 11:00 AM
FYI- Home Depot has about the cheapest price for the camco water
heater element.
See the FAQ water heater section.
Here's a link-
http://www.forestriverforums.com/for...ent-39334.html
New element about $10
Socket wrench to fit about $8
They don't carry the T-stat/hi limit tho....
Peace!
Dan & Rita D
01-12-2014, 11:29 AM
Hey guys, I haven't used one of these below, but for only 12-14 bucks per, it seems it would be easier than trying to weld something to the thin metal element socket. Just use with ratchet (or breaker bar) and extensions. Maybe one of our other members has experience with one and can avow for them.
The Camco one had reviews from fellow rv'ers for it on Amazon.
Just a suggestion. Feel free to hate it.
Camco 9953 Professional Water Heater Element Socket - Amazon.com
TEKTON 1828 1/2-Inch by 1-1/2-Inch Water Heater Socket - Amazon.com
2011 Flagstaff 831 RLBSS
01-12-2014, 11:46 AM
Originally Posted by wmtire
Gave $8 for the sheet metal socket and I have a bunch of old 1/2" sockets. Labor is free as is the scrap metal for top and mig welding. Your suggestions are ideal for those without the means to mod the sheet metal one.
01-12-2014, 12:58 PM
OC is just not happy unless he is makin' sparks or weldin' sumptin.
Brenda and John
Master Blaster of the Navy
01-13-2014, 12:55 AM
Are the anode and element the same size/use the same size socket?
Jerry
2007 Surveyor SV 230
2013 F150 Ecoboost
01-13-2014, 08:09 AM
Nope. The heating element is much larger.
(don't have the exact sizes right in front of me but someone will likely
post them.....)
01-13-2014, 08:28 AM
1 1/2in. 6point 1/2drive Youroo!!
01-13-2014, 08:38 AM
post them.....)
The plastic plug for mine is 3/4 inch.
01-13-2014, 09:03 AM
Heating Element: 1 and 1/2
Anode Rod: 1 and 1/16
01-18-2014, 11:35 AM
After installing the Suburban 232317 140° 120V Thermostat and using it for a week, we are absolutely delighted with it. We use a lot less hot water due to the 20° increase in temperature, therefore less electricity and propane. Went online and contacted RV Supply Parts and bought 2 more 140° thermostats for $42 including shipping to keep around for spares just incase I have another "brain fart".
Would never consider using a 120° thermostat again, so even with the cost of the brain fart I had, we came out with a much better hot water system.
01-18-2014, 11:44 AM
So even your "brain farts" mod your trailer...
Figures!
