Old 08-05-2015, 02:08 PM   #1
Suburban Water Heater
I have a SW6DE Suburban water heater. On the side it says model 5034. I can't seem to find that model anywhere. Are these hot water heaters interchangeable with other models like 5058A etc. What is the difference. I would like to replace mine if I can. Thanks
kappy32 is offline   Reply With Quote
Old 08-08-2015, 07:30 PM   #2
Jerry01's Avatar
I can't help with the interchangeability but I'm wondering why you are wanting to Change it. Is it the capacity or something else? I "believe" all models are interchangeable in regards to size. Are your looking for a larger model? Jerry
2005 GMC Sierra 2500HD, Duramax 2WD CC/SB
2013 Cardinal 3030RS full body paint
B&W Companion slider, air bags, EFI Live Custom tuning by So Cal Diesel
Jerry01 is offline   Reply With Quote
Old 08-09-2015, 09:30 AM   #3
hot water heater
Just was wondering. Actually have taken care of the issue. thanks for the reply.
Old 08-10-2015, 11:33 AM   #4
I think I am having a problem with my Hot Water temperature. I have had the Rockwood for three seasons now. Late last year we experienced problems with the water heater. Brought it back to dealer for check up and all they did was hit the reset buttons and the unit (Gas) came on. Always worked on Electric. While away this past week the Gas would work intermittently. While testing it the gas stayed on so long the Pressure Relief Valve started to leak. I shut it down and worked off of Electric the rest of the week.
Any idea what the Temperature should read on both the Electric and the Gas?
TIA
Jack
jjhill is offline   Reply With Quote
heater, suburban, water, water heater
