Old 11-24-2015, 03:58 PM   #1
Suburban Water Heater
I have a Suburban water heater on a 2016 Flagstaff Super Lite Classic. I've winterized the travel trailer and pulled the anode on the water heater to drain it. I set the by-pass and released pressure before draining but I noticed that there was about an inch of water still left in the bottom of the heater. I suppose I could use a syphon to get the rest out but my question is will it hurt to leave an inch or so of water in the bottom?
PCStrope is offline   Reply With Quote
Old 11-24-2015, 04:09 PM   #2
Likely won't hurt but since the Suburban is a steel tank and depends on the anode rod submerged in water to slow corrosion to the tank lining, I've always inserted a small hose and siphoned the last remaining bit out.
Days Camped: '16=46 '17=30 '18=51 '19=36
Old 11-24-2015, 06:13 PM   #3
A little water in the bottom of tank is OK.
I remove anode, let the tank drain then re-insert the rod finger tight.
I have being leaving the last bit of water in the tank for eons and never had a problem here in the great white north where temps get down to -40 at times.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
2009 F150 - 5.4 Litre - Tow Package
Boon Docking 99% of the time.
boondocking is offline   Reply With Quote
Old 11-24-2015, 06:23 PM   #4
mjones12's Avatar
With room for expansion, a little water won't hurt.
2018 Coachmen Apex 249 RBS
2010 Silverado LT 5.3 V8
The world is a great book, of which those who never stir from home
read only a page. - St. Augustine
mjones12 is offline   Reply With Quote
heater, suburban, water, water heater
