Old 03-20-2014, 09:35 AM   #21
TURBS's Avatar
Originally Posted by youroo View Post
By (Bomb) I am referring to the Rubber plug (Temporary) that he put in the drain hole. Many members have removed the (3/4 NPT rod) while still under water Pressure and found out what (Water Bath) comes out! Thus if the (Rubber Plug) lets Go,here comes the water and there goes the (Heating Element) if equipped! There are (Many Members) that remember their (First Bath) from removing the (Anode)! Youroo!!
I brought soap and shampoo.
TURBS
Sabre owners united!
Old 03-20-2014, 09:38 AM   #22
TURBS
Don't know about the shampoo, but you could sure use the soap!
Old 03-20-2014, 10:09 AM   #23
PhoneDude 8289's Avatar
One could drill it out and tap it to a 1"NPT and use a 1"x 3/4" bushing and install a new anode rod into that.
Joe & Beverly
2014 Ram CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is offline   Reply With Quote
Old 03-20-2014, 10:31 AM   #24
Only if there is enough metal left to tap it out to 1". I think he can tap it deeper with the 3/4" and run the anode in a little farther. That's the advantage of a tapered thread.
Old 03-20-2014, 03:52 PM   #25
KyDan's Avatar
That's what I think too. My anode barely goes in there 1/3 of the threads.
The factory threads could easily be tapped deeper in mine.
I wonder if that's not the fix for dwcjb as well.
Old 03-20-2014, 04:01 PM   #26
Me, being the cheapskate I am, I'd sure give it a try. Nothing to loose! Heck, I'd even go so far as trying to braze the existing stripped one before I'd replace the whole thing. (I'd take it out of the coach first and fill it with water tho')
Old 03-20-2014, 06:21 PM   #27
Good thinking OC. First option should be to try and tap it deeper.
Joe & Beverly
2014 8289WS lifted
Old 03-21-2014, 10:51 AM   #28
Try hardening Permatex - be sure and let it cure before adding water. I frequently use it on the gas tank petcock of old motorcycles, which have a tendency to leak. Once it is dry and cured it is fairly tough stuff.
cadman99 is offline   Reply With Quote
anode, heater, suburban, water, water heater
