Old 03-18-2014, 07:08 PM   #1
Retired May 2015
Suburban Water Heater anode
Previous owner evidently removed and changed the anode rod. Must have stripped the threads as the leak. I removed and added Teflon tape, tightening as much as I dared. Have googled and a 1/2 NPT thread chaser/cleaning tool was recommended. It doesn't seem to exist, I have the NPT tap and have tried it but not enough meat. What recommendations/options does anyone have? My obvious choice is to replace the entire unit but it works perfectly. BTW to fix the leak I employed a short term fix was to use a twist in rubber plug, but certainly not at permanent solution. Thanks
Dennis & Carol
2005 Bulletproofed F-250 6.0 Crew Cab/Long Box
2007 Forest River 38 ft Sierra
Retired 4/30/15
Traveling with new pup "Sammie". Boston Bull Terrier/chihuahua (Bo-huahua). Pronounced Bow wow wow.
dwcjb is offline   Reply With Quote
Old 03-18-2014, 07:19 PM   #2
Plain Old Member
Is there anything you can coat the worn threads with, let it set, then chase with the tap? I can't think of anything other than JB weld and I don't know if that would work, but I'm sure there is something that would bond to the old threads and accept the tap without coming off.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 03-18-2014, 07:26 PM   #3
Plain Old Member
A quick google search and there are definitely quite a few products for doing just what you need to do.
http://www.amazon.com/Loctite-Form-A.../dp/B000WSEUII
Loctite Epoxy Weld Bonding Compound from Loctite Adhesives
Old 03-18-2014, 07:30 PM   #4
davel1971's Avatar
how is a rubber plug sealing under pressure but not the anode rod with Teflon tape?
David & Lynn
Old 03-18-2014, 07:46 PM   #5
Jack of All Trades
RJHuser's Avatar
Assuming there are some threads left in the tank connection, and you have cleaned them up with the tap, You could try the following:
New anode rod
Apply a light coat of heavy-bodied pipe dope (Slic-Tite PTFE or similar)
Apply 5 to 6 wraps of "GOOD" Teflon pipe thread sealant tape (Mil grade)
Apply a heavy coat of heavy-bodied pipe dope (as above)
Insert anode rod into tank, tighten 1 to 2 turns past hand tight using a 1-1/16"
socket and ratchet with an extension
Wait 24 hours before adding water and pressurizing tank
If it still leaks, tighten 1/2 turn at a time until it seals
I do a lot of stainless steel piping (stainless steel pipe and fittings are extremely difficult to work with and seal) and this will generally give a tight seal.
Rick
Rick & Debbie; Brandy Schnoodle & Bucky (Dexter & Fritz R.I.P.) the Doxie "Kids"
2015 Jayco Pinnacle 36RSQS 5'er
2018 GMC Sierra Denali 3500HD, 6.6L Diesel Dually; B&W Companion 5'er hitch
ScanGauge, TST 507 TPMS
RJHuser is offline   Reply With Quote
Old 03-18-2014, 08:51 PM   #6
Retired May 2015
Thanks. I will try when I get home from morro bay, ca coast. Rubber plug has a a t-handle to tighten no drips. Not enough threads to restart a new anode. I tried. I may try the loctite product. Never gave that a thought.
Dennis & Carol
Retired 4/30/15
Old 03-18-2014, 09:29 PM   #7
SKnight's Avatar
Call and check with a plumber. Surely there's a permanent fix for this issue.
Old 03-18-2014, 09:44 PM   #8
Old Bones's Avatar
I wonder if you can get a Heli-Coil insert for something like that, to replace the threads.
2013 Forest River Surveyor SP296
Old Bones is offline   Reply With Quote
Old 03-19-2014, 05:23 AM   #9
davel1971's Avatar
I don't think you can heli-coil pipe thread, since it is tapered.
David & Lynn
Old 03-19-2014, 06:14 AM   #10
No No No,the Suburban Drain hole is (3/4 NPT). Now throw that (Rubber Plug) away,you have just built a Water Heater (Pipe Bomb)! Youroo!!
anode, heater, suburban, water, water heater
