Old 04-06-2012, 12:45 PM   #11
HemiCab's Avatar
Thanks Turbo, if it is the breaker where can you get a new one?
We are camping so for emergency use the gas will keep us going during use and keep the electric to maintain.
HC
2008 Dodge Ram 2500 QC CTD 4x4
2014 Cherokee 284BH
Equalizer 1,200/12,000 WDH
TST 507RV TPMS
MaxBrake BC
HemiCab is offline   Reply With Quote
Old 04-06-2012, 12:49 PM   #12
Take the defective breaker to HD or Lowes or a hardware store and get a duplicate.
Old 04-06-2012, 02:38 PM   #13
Herk7769's Avatar
Try removing all power from the power center.
(Battery too just for safety)
Remove the face cover on the power center.
Swap the wires from the circuit for the water heater with another one of the same amperage.
If the problem moves to the new breaker; the circuit is the problem.
If it works fine, the change the original breaker.
HAM CALLSIGN - KC3FFW
Old 04-06-2012, 05:16 PM   #14
HemiCab's Avatar
Could this be my problem?
I got a new breaker before looking.
HC
2014 Cherokee 284BH
TST 507RV TPMS
MaxBrake BC
Old 04-06-2012, 05:50 PM   #15
TURBS's Avatar
Wow! That's interesting!
Old 04-06-2012, 07:02 PM   #16
Herk7769's Avatar
HC
Wild guess. Check the wire... It looks bad
Loose hold down screw caused a high resistance connection that got hot enough to burn the wires.
See my point about resetting a popping breaker without finding out why?
Old 04-06-2012, 08:48 PM   #17
HemiCab's Avatar
Herk, Point taken!
Next time I will dig deeper.
I am not sure if I should try to ever use the old breaker again....probably put it in the garbage.
Thanks for all the help.
This trip has been full of adventure, flat, water, breaker, satelite. More about all that when I get back to the house.
HC
2014 Cherokee 284BH
TST 507RV TPMS
MaxBrake BC
Old 04-20-2012, 12:42 PM   #18
Hambonethecop's Avatar
Just a little added information if anyone searchs for this type of weater heater problem 2012 Flagstaff H2O not working on electric, gas was fine kicked the 15amp breaker in "box" took it to dealer for repair dealer found either suburban wired it backwards or wired wrong by Forest River during build I'd never figured taht out great dealer support
Hambonethecop is offline   Reply With Quote
breaker
