11-20-2015, 02:37 PM
Suburban Water Heater Drain
I have a 2016 Classic Super Lite 831RLBSS that I'm trying to winterize. The sales people were no help when it came time for the walk-around concerning much of anything about the travel trailer and the "Owners Manual" was generic at best. Needless to say I plan on posting a lot of questions. First: how do you drain the water heater? I configured the bypass valves in the back of the unit and opened the pressure relief valve. There doesn't seem to be anything on the bottom of the unit except what looks like the (anode?). How can I tell if the water heater is empty? Again, the owners manual was of little help.
11-20-2015, 02:43 PM
Take the anode out.
11-20-2015, 03:09 PM
Use 1 1/16 inch socket
Fonzie
11-20-2015, 03:45 PM
You have to remove the anode rod.
(See where I marked your photo)
11-20-2015, 04:57 PM
Thanks. I removed the rod and the water heater drained.
11-20-2015, 05:03 PM
When you reinstall the anode, put no more than 1 1/4 turns of Teflon tape on the threads.
Snug the anode down to where it does not leak. Suburban calls for 7 foot pounds of torque, but not leaking is good. Some leave the anode out until they de-winterize, but I don't recommend that. You want the anode to do what it is supposed to do all of the time.
2014 Solera 24R
USN Retired
11-20-2015, 05:14 PM
The only reason I leave the anode in when I winterize is to keep the threads from getting all rusted up. It doesn't really serve much other purpose if there's no water in the tank.
11-20-2015, 05:30 PM
I agree and will add reinstalling also keeps bugs, spiders or anything else out of an empty tank.
11-20-2015, 06:02 PM
If the threads are rusting, what do you think is going on in that steel tank.
Just a thought. The anode is sacrificial metal that will corrode (oxidize) first due to the electrolytic action between the steel and the anode as long as there is air and humidity. You ever see a piece of steel laying in a garage out of the rain rust ? That's just me.
2014 Solera 24R
USN Retired
11-21-2015, 01:31 PM
"DITTO"
FOREST RIVER FW 8524RLWS
2010 FORD F 150 5.4
#1-18' Nomad #2- 20' Mallard #3- 27' Sunline #4- Four Winds C #5- Innsbruck 40' PARK # 6- 28' Amerilite #7- Forest River 26.5 FW ( 1st FW)
11-21-2015, 01:54 PM
Low Point Drains
Im storaging for summer for six months, so no threat of freezing. Are the low point drains (fulltime plumbed connectors) enough to empty hot and cold waters? Or should I take the hot water plug out and empty the filter?
11-21-2015, 05:09 PM
+Suburban heater drain
Note: Plug requires 1 1/16 socket. I made two trips to Lowes before I got the right size socket. All my socket sets stopped at 3/4 inch. Draining g is easy once you break it loose.
11-21-2015, 05:43 PM
Too old to be too smart
The truck-size tire rim lug "star" wrench has a 1-1/16, as well. The lug wrench makes removing it easy.
The only caution is when you replace the anode to not over-tighten it if using that wrench, because you easily CAN!
Pop
Terry 250RKS, perfect for the two of us and the pups.
2000 F-350 7.3L CC/LB 4WD Lariat 3.73's
11-21-2015, 05:50 PM
I've got the same WH, 27mm works just as well. Mark it with a Sharpie because next year you will ask the same question, "what size is it?"
2017 F350 Dually 6.7
2019.5 Hathaway
He who dies with the most tools, wins!
11-21-2015, 05:54 PM
The electrolytic action with air and humidity in an empty HW tank.........can you explain that?......a friend was asking.
11-21-2015, 07:05 PM
I went one step farther. Threaded a piece of 3/4 PVC , pull the anode and insert the 3/4PVC and all the water drains out side and when finished the PVC stores upright in the corner.
11-21-2015, 07:54 PM
The 3/4 PVC pipe reduces the drain hole,better to not have for additional opening size! Youroo!!
11-21-2015, 07:57 PM
I have a 2016 Classic Super Lite 831RLBSS that I'm trying to winterize. The sales people were no help when it came time for the walk-around concerning much of anything about the travel trailer and the "Owners Manual" was generic at best. Needless to say I plan on posting a lot of questions. First: how do you drain the water heater? I configured the bypass valves in the back of the unit and opened the pressure relief valve. There doesn't seem to be anything on the bottom of the unit except what looks like the (anode?). How can I tell if the water heater is empty? Again, the owners manual was of little help. Attachment 94667
Note,dont forget to return the pressure relief valve to it Seated location! Youroo!!
11-22-2015, 01:36 AM
The low point drains will drain the lines but not the water heater. To keep the water from getting stinky, even though you are not looking at freezing temps, draining the heater would be a good idea. There is also water below the water heater drain point you can flush and siphon out.
PS: Atwood users, the plug is 15/16"
Land of 10,000 Lakes
2016 Forester MBS 2401R
2016 FR Forester 2401R
Towing 2014 Honda CR-V
11-22-2015, 04:40 AM
Cheers for that
