Old 03-24-2019, 12:58 PM   #1
Suburban Water Heater Issue - 12 Gallon Tank
Today was a greaat day to flush my Suburban water heater tank. I pulled the anode rod and opened the pressure relief valve to drain the tank. To my surprise the tank started to empty very slowly.
I used a probe to clear the blockage at the anode rod hole and out came some gel-like substance. The opening kept getting clogged and I had to keep working it to clear it to allow the water to drain.
The pictures below show some of the debris that came out of the tank. Has anyone seen this before? I am leaning toward an internal failure of the tank. The hot water has not lasted as long as it usually does (12 gallon tank). I am the original owner of the 2014 Dynamax Trilogy and perform regular maintenance on the camper and water system.
John
You can see some of the junk that came out just below the burner pipe.
Collected some of the debris and put a quarter in the picture to give an idea of size.
2014 Dynamax Trilogy 3850RL - South Hampton Interior, Full Body Paint (Black / Silver / White), MOR/ryde Independent Suspension, MOR/ryde Disc Brakes, ONAN 5500 Generator, Progressive Industries HW50C w/Dual Display, Winegard HD Dish w/DirecTV, Washer & Dryer, iSprings 7-stage Reverse Osmosis Water Filter, Trail-Air Flex Air Pin Box, Third AC installed, AC Voltage/Amp Meters, DC Amp Meter, Garnett See Level Tank Sensors, TST 507 TPMS
Retired USAF - Full Timers!
John Hagen is offline   Reply With Quote
Old 03-24-2019, 03:45 PM   #2
Bill and Gail's Avatar
It looks like a slime build up. I saw this in a fish tank once. I would get a water heater flushing adapter for the water hose and flush the water heater. Then I would put the old anode plug back in, remove the pressure relief valve, fill the heater with a mixture of bleach and water, let it sit 24hrs, then drain and flush again, hopefully that will clean it out.
Bill and Gail is offline   Reply With Quote
Old 03-24-2019, 03:59 PM   #3
PPST Wannabe
kenandterry's Avatar
Great photos John. What does your anode look like?
I suggest you need to really power rinse your water heater. Filling it with water and vinegar might be an idea too.
Have you got one of these?
It’s like a giant size of the thing the dentist uses on you.
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is online now   Reply With Quote
Old 03-24-2019, 07:38 PM   #4
The anode rod had some of the junk on it as well. I did power flush the tank with the tank wand. A lot of junk came out, including the debris from the anode rod sacraficing itself.
This is really odd. We have lived full time in the RV since Feb 2014. It has never been in storage. We have boondocked with it as well. Never had any issues. Just normal annode rod debris and that was it.
We are currently on Altus AFB and have been here since Aug 2018. The water here is dirty (I have to change whole house filter very often). I have complained to the base water department. They are next to worthless. They just open spigots and "flush" the pipes. Doesn't do a bit of good.
Will check the tank again in a week or so and if it is building up again I'll go with the bleach or vinegar suggestions.
Thanks to you both for the info.
John
Old 03-24-2019, 07:48 PM   #5
Herk7769's Avatar
This is completely normal.
The sacrificial anode and any calcium in the water will make debris/gel at the bottom of the hot water tank. This is why you ALWAYS isolate the water heater with the isolation valves and drain the tank through the outside anode/drain port. That junk will get sucked into your inside cold water pipes if you drain via the low point drains.
ID:	199696   Click image for larger version
ID:	199698   Click image for larger version
Name:	Anode Protection 10 Gallon.JPG
HAM CALLSIGN - KC3FFW
Old 03-24-2019, 07:51 PM   #6
cavie's Avatar
John
Attachment 199580
Attachment 199581
Attachment 199582
That's the same thing I have found in my house WH evey 2 years when I drain it. just clean it out and move on.
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
cavie is online now   Reply With Quote
Old 03-24-2019, 08:01 PM   #7
Herk7769's Avatar
John,
As far as the "the hot water does not last as long", you can check:
1) The water heater winterizing isolation valves. The crossover valve may be open (or partially open) causing cold water to mix with the hot water coming out of the heater. See photo
2) The outside shower wand valves may be open and the wand handle shutoff cross-valve button closed. In that case, cold water may be mixing through the open valves.
Herk
Old 03-25-2019, 12:54 AM   #8
Thanks Herk and Cavie. In my 10+ years of RV ownership and 30+ years of owning a house I have never seen the gel stuff. The anode rod debris, yes I have seen it and understand it. I know the water here is pathetic and constantly fails water testing standards. Maybe that is reason for this gel junk.
Will see what it looks like in a week or so.
As for the hot water not lasting long... The RV has never been winterized or put in bypass. All of the valves for those tasks are behind a basement wall. They should still be in the condition they were in when installed in 2014. I suppose they could be failing and leaking but I kinda of doubt it. However, it has to be something and your suggestions are valid. Will have to open up the panels in the basement to check it out.
Thanks again for the suggestions!
John
Old 03-25-2019, 06:02 AM   #9
Herk7769's Avatar
Check the valves in your outside shower; that my be the culprit.
My house water heater had so much gel it had plugged the drain. Water pressure did not help; I stuck a wire up there to free it and it painted the cellar with that goop.
Took forever to clean it up.
Old 03-25-2019, 06:31 AM   #10
nomad297's Avatar
John
Attachment 199580
Attachment 199581
Attachment 199582
Many of us plumbers refer to that stuff as “oatmeal” because of the way it looks and the consistency of it. It is mostly calcium deposits. I replace 3-4 residential water heaters every week and every one of them has this stuff in them — even those where the homeowner has flushed it regularly. Most of the heaters won’t drain quickly enough, if at all, because of this stuff, so we almost always just connect a pump to the drain and suck it out. Quite often, we have to remove the boiler drain from the heater and quickly swap it out with a 3/4” nipple because the openings in most boiler drains are so small, they clog.
It’s nothing unusual or something to be worried about. Just flush it out and go on with life.
Bruce
nomad297 is online now   Reply With Quote
heater, suburban, tank, water, water heater
