Old 07-05-2013, 06:55 PM   #1
PPST Wannabe
kenandterry's Avatar
Suburban water heater problem
We have the SW10DE model equipped with both electric and LP gas heaters.
LP gas part works fine.
Electric part was working fine so far this season but lately, does not seem to be heating the water. I checked the fuses and breakers in the distribution panel. The fuse for the water heater appears solid, and the breaker was switched off then back on. I pressed both the "RESET" buttons on the front of the water heater, and removed the plastic cover to confirm both fusible links (AC and DC) are good and intact. The on/off switch for the electric control is "on". The tank was never empty since the last time the electric heating element heated the water effectively.
Aside from removing the electric heating element and testing for continuity, am I missing something?
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
Old 07-05-2013, 07:07 PM   #2
fonzie's Avatar
If you have a multimeter, see if you have 120 volts ac across the heater terminals.
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 07-05-2013, 07:33 PM   #3
Witch Doctor's Avatar
If you disconnect the wires from the element and ohm the element out if you get a reading it is not the entitlement. Mine just did the same thing I would only get luke warm water on electric. I installed a new stat and I'm back to very hot water again.
Coachmen M/H
Concord
2018 / 300 DSC
Witch Doctor is online now   Reply With Quote
Old 07-05-2013, 07:42 PM   #4
VinceU's Avatar
Water heater
In addition to that, if you don't have 120 across the heater when on, check the "thermostat" which is the round device attached to the OL link and below the reset button. The thermostat is under the small cylinder and if not closing with cool water the element cannot turn on. When the water warms to temp this thermo will open to prevent overheating. Mine failed last year. Its all one assembly, thermo, OL link and the reset button for high temp.
Old 07-06-2013, 09:04 AM   #5
PPST Wannabe
I will check the heating element next time I get to the rig. I will check to see if 120 volts is getting to the element, and with wires removed, I will check for continuity across the element.
With the suggestion of replacing the thermostat unit (which includes the thermo, link and reset button) where can you get one, and approximately what price range?
Thanks all.
Ken and Terry
Old 07-06-2013, 09:12 AM   #6
VinceU's Avatar
Thanks all.
Dometic choice of set temps i remem about 34.00, CW, PPL and other net providers high 20's? They don't fail often, but they do fail regular! Warranted for two years.
Old 07-06-2013, 01:52 PM   #7
Thanks all.
Mine was under warranty but the price tag on it said $39.00.......
Coachmen M/H
Concord
2018 / 300 DSC
Old 07-06-2013, 02:44 PM   #8
VinceU's Avatar
So sorry, I specified Dometic instead of Suburban as source of thermo...
Too many posts lately about awning failures!
