Old 07-23-2016, 09:40 PM   #11
Originally Posted by SeaDog View Post
I was leaning toward the high limit switch, but if it works on electric sort of rules that out. You might want to check the gas pressure at the valve with a manometer and ensure you are getting proper pressure.
Not necessairly. There are two seperate limit packs. One is 120VAC, which is on the left side. The second one is 12VDC. Which is used when using propane. To check the limit switch packs, remove the rubber cover which is about mid height on the left side of the heater. Using an ohm meter check for contunity.
Using compressed air set at about 25PSI be sure to blow out the orifice tube too.
donniedu is offline   Reply With Quote
Old 07-24-2016, 12:09 PM   #12
RVdoctor
Make sure the ceramic on the ignitor is not cracked or loose and connections are clean tight. I've also seen power boards pass bench test and still not work when installed on the unit. Remove reset button cover, check tsat, and eco connections. You can bypass the eco and tsat with a jumper wire to see if that is the problem. Just make sure you don't bypass for more than a couple of minutes.
rvdoctor is offline   Reply With Quote
Old 07-24-2016, 02:39 PM   #13
kenandterry's Avatar
Our cell and Internet service is minimal at best over the next few days as we travel.
I have full operation of the electric circuit for the water heater for the rest of the road trip.
I'll update and continue working on my propane problems with the water heater when I get home.
Thanks for everyone's input and suggestions so far, and I'll get back to you all soon.
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
Old 08-09-2016, 01:21 PM   #14
Okay.
Back on the Homefront. Didn't do any work at all to the water heater.
Now when I start the water heater using propane, I turn on the switch, the interior red light lights for a few seconds, the light goes out, the burner fires up and it heats the water. So....when I started this thread, I had a propane problem with the water heater. No I don't?
The flame is pretty much a blue colour, so that's good. Not sure if it's the hottest flame available, but I do hear the roar of the burner. Is it necessary to have a professional repair person judge if it's burning 100% correctly?
I can't fix what's not broke right?
Ken and Terry
Old 08-09-2016, 01:23 PM   #15
Altitude issue?
Old 08-09-2016, 02:56 PM   #16
Location: Full timer,,,at Lake Georgetown in central Texas for the winter.
kenandterry,,,,,sounds like it's running normal.....yes, a blue flame,,,,yes, a dull roar,,,,yes, hot water.
Grampa Jim is offline   Reply With Quote
Old 08-09-2016, 03:22 PM   #17
Originally Posted by donniedu View Post
Altitude issue?
X2 - recent thread about fridge not working above 9000 ft. Where were you when you were having problems? Was your fridge running OK on gas?
2012 Roo19 - hybid (2012-2015)
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
Old 08-12-2016, 09:33 AM   #18
We were just touring around Northern Ontario when the propane water heater trouble started so elevation is not an issue. And yes, all other propane appliances worked fine on full tank.
Just one of those things I guess.
Ken and Terry
gas, heater, suburban, water, water heater
