01-03-2016, 02:54 PM
Suburban water heater question
So many things all at once. We've been full timing in an RV for a month. It is brand new. Recently I've noticed the pressure release valve on our hot water heater has been dripping. Googling that seems to indicate that sometimes it can be normal. However, just recently the hot water heater has started making pinging noises. Also when you run the kitchen faucet or any other faucet in the house, the hot water heater makes what can be best described as a squealing noise. The noise lasts approximately a second or so. Of course we return to Google and lots of things say that might be the water heater check valve. We called a mobile RV mechanic in the area. He suggested we just run it on propane for a few days and see what happens. I did run on propane some yesterday and did note that the pressure release valve still leaked occasionally.
Thoughts?
01-03-2016, 02:58 PM
O and another weird thing, that singing nose occurs when you turn on other faucets hot or cold anywhere in the house.
01-03-2016, 02:59 PM
Is this all at the same campground? Have you tried or do you use a pressure regulator on your water connection in case the site water pressure is high?
Orval and Yvonne
2016 Flagstaff 27RLWS Emerald Package
2011 F150 SCrew XTR 5.0L 4x4
01-03-2016, 03:09 PM
Try opening the pressure release valve for an instant and close it immediately. Sometimes this will reseat the valve plunger and stop the slight leaking. Of course, be extremely careful not to get burned with the hot water spraying from the valve when it's open for an instant. Also, a few light taps with the handle of a screw driver on the flip latch of the valve will also seat it and stop the dripping. Try the tap on the flip latch before you try the instant open, be safer and less mess if it works!
PS- take the pressure off the system with either of these processes for best results!
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
01-03-2016, 03:57 PM
https://youtu.be/4QcMM7Z41vo. This is a video of the noise it makes. Inside the water is being turned on and off as the noise is made. If you switch the electric off, it instantly stops.
01-03-2016, 03:58 PM
Agree with opening pressure relief for an instant, just be sure to turn of the electricity to w/h first, then turn it back on when done. May just be some debris or sediment in the relief valve.
01-03-2016, 03:59 PM
We are using a pressure regulator. We went through the procedures to reset the air bubble inside. No change.
See video of it whining:
01-03-2016, 08:48 PM
Any theory on that noise? Could the heating element have enough lime on it in a month flat to do that? I found a site that described a similar noise and it was calcified build up on the heating element? I don't feel comfortable removing the propane assembly to check the element though. Thoughts?
01-03-2016, 08:52 PM
Should be able to just unscrew the electric element; takes 1 1/2 socket or can buy a tool at RV supply stores. No need to remove anything to get to element, just the 2 wires on it.
01-03-2016, 08:55 PM
I could get to the anode, but the element is squarely behind the propane assembly.
01-03-2016, 08:59 PM
Correct, you'll most likely need to remove the burner tube.
KyDan has a tutorial on the replacement of the element in the FAQ section, link below. It may help if you ever have to go that route.
http://www.forestriverforums.com/for...d-r-50292.html
2011 Flagstaff 831 RLBSS
01-03-2016, 09:02 PM
Sorry for the bad info. That does make it more of a challenge. Good luck.
01-04-2016, 12:57 PM
If the singing stops when not using the electric element, could this indicate a faulty high limit switch on that side? After a cool down, you might pull the anode and flush the tank of any mineral build up. Good way to see if the tank has been contaminated.
"Lurch" = Georgetown 2011 330TS
Toad = Jeep 2016 Cherokee
Pilot = Bob
First Mate = Xiangbing
Crew = Radar, NiuNiu & NaNa
01-04-2016, 02:59 PM
CDR USN Ret
From Suburban's Installation and Operating Manual:
"The temperature and pressure relief valve is designed to open if the temperature
of the water within the heater reaches 210°F,or if the water pressure in the heater
reaches 150 pounds. Recreational vehicle water systems are closed systems and
during the water heating cycle the pressure build-up in the water system will reach
150 pounds. When this pressure is reached,the pressure relief valve will open
and water will drip from the valve. This dripping will continue until the pressure is reduced to below 150 pounds,and the valve closes.This condition is normal and
does not indicate a defective relief valve"
2015 XLR415AMP
2011 3500HD Duramax/Allison/90 Gal Aux
2015 HD Limited Low
01-04-2016, 03:25 PM
CDR USN Ret
Pinging - I've never seen an electric hot water heating element that, after a period of time, did NOT ping. It is due to scaling on the element building up, and when the element energizes, differential expansion of the scaled element results if this 'pinging". As for the "squealing" - Appears to not be a water heater originated sound (squeal happens both hot and cold). Most (all?) hot water heaters do not have integral check valves. Suburban further recommends a check valve not be installed immediately at intake of heater. There is however, a check valve at the city water intake hose connection. Check valves can squeal at initiation of flow through them. To test, I'd disconnect city water, turn on unit water pump, then open faucets - if no squeal, noise is likely from the city water inlet check valve. Changing water regulator pressure pressure may remedy issue.
2015 XLR415AMP
2015 HD Limited Low
01-04-2016, 09:52 PM
Campground host Mo. State
Try hooking up your water connection without the regulator, some times they squeal when you use any water tap.
Frank & Kathy & Daisy 2.0 Yorkie (Pack leader)
2008 Ram 6.7 Diesel, 4.10 diff., EGR valve delete, MBRP straight exhaust, Mini Max race tuner, K&N
2016 Crusader 321 RES Ham call W0FCG
Days camped in 2015- 111 in 2016-75 in2017-61
01-06-2016, 12:10 PM
I agree that the valve may not be seething properly. However before opening that relief valve I would take all the pressure off. Water tank by opening the hot water valves at the sink. You will need to show your water supply off first and then shut your electric off at the heater. Then drain the pressure and then open and close the relief valve a few times. Then turn the water back on and then turn the electric on.
I also agree it is possible to supply water is that too high of a pressure. I always use a pressure valve on my supply water. They are cheap and well worth having.
Jim
07 Dodge 1500 crew cab with 20" wheels, 08 Forest River Rockwood Signature Ultra-lite 8280SS
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man."
George Bernard Shaw
