Old 08-12-2014, 08:41 AM   #31
BandJCarm's Avatar
I have the same setup. Being the dumbest member of this board, I didn't know for many months that I even HAD an electric wh capability!!!
Now that I know it's there, it's sort of a minor issue to turn it on. Course, I always forget to, and leave it on propane, but.......as I said...............I ain't real bright.
BandJCarm is offline   Reply With Quote
Old 08-12-2014, 08:52 AM   #32
wmtire's Avatar
Originally Posted by Deacs1 View Post
I did more research the model # is SW6D, gas only. That makes sense
Because there is no switch on the outside panel. Got this info. off a Suburban
website. Does this sound correct?
Originally Posted by BigJohnD View Post
Deacs1, you are correct. Gas only water heater.
X2 with BigJohnD. Here is a spec sheet with the different model numbers of Suburbans for future.
Name:	FireShot Screen Capture #119 - 'Airxcel I Suburban Manufacturing Products' - www_rvcomfort_com_s.jpg
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 08-12-2014, 04:50 PM   #33
No switch
Mine does not have a outside panel AC on/off switch.
It is a 6 gal. Suburban WH so it has to be model# SW6D.
Just bought this TT (2) months ago, I have a lot to learn.
So I will fill the propane tanks and try it out.
Thanks everyone for info.
Deacs1 is offline   Reply With Quote
Old 01-13-2018, 07:51 AM   #34
GB
gbrown's Avatar
No Inside HW Switch
I have to side with the original poster on this one. Coming from an Outback which had both gas and electric switches on the inside to a Wildwood which has the gas switch on the inside and the electric switch on the outside, having both switches on the inside was way more convenient. The argument about making things more difficult because a few people forgot to put water in the tank before turning it on doesn't hold water (pun intended). Instead, what happened with me was I had mine at home on shore power to keep the batteries charged and forgot to turn the electric HW switch off (remember it's now outside out of sight behind a cover) and ended up boiling the HW heater dry and burning it out anyway. I would much rather have a lighted rocker switch inside on the control panel so it's easy to see and use.
2015 Ram 2500 SLT 4x4 Cummins
2015 Wildwood 327RES
Pullrite Superglide 16k
gbrown is offline   Reply With Quote
Old 01-13-2018, 08:46 AM   #35
Mr. Dan's Avatar
... and I have the opposite view. When I break camp and unhook my water hose from my trailer, I'm standing 2 ft. from the water heater and I flip the outside switch to turn OFF the electric heating element. I don't flip the switch in any direction until I hook up my water hose at the next campsite. When I hook up the hose and test for flowing water (by flipping open the pressure relief valve which is outside and also on the heater face), I turn the electric element ON. I've never felt the need to turn my electric element ON/OFF in the middle of a camping trip.
BTW, the OP hasn't logged on to the site in almost 3 years. I guess he resolved all RV questions one way or the other.
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 28; booked = 34
Old 01-13-2018, 09:10 AM   #36
Glad you said something Dan. Last time I mentioned an old thread to someone, I got my butt reamed by other posters.
TheWolfPaq82 is offline   Reply With Quote
Old 01-13-2018, 09:24 AM   #37
Oaklevel's Avatar
Our last camper being 30A I never saw a need to use the electric side (As the water heater uses so little propane). We needed the electric for other things. But having said that our older campers only had a propane side.......
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Old 01-13-2018, 09:46 AM   #38
gbrown:
If you want to add your own switch, see post #13 here:
Inside water heater switch
2011 Traverse LT, 3.6L, FWD
Old 01-13-2018, 12:25 PM   #39
What I like about my Attwood WH, inside switch and no anode.
Frank
Frank & Brenda
Thor Windsport 27K TST 507 Tire Monitors
2012 Jeep Liberty Limited Jet 4X4, Hopkins TOWD light wiring
FrankMor is offline   Reply With Quote
Old 01-13-2018, 02:42 PM   #40
bikendan's Avatar
Holy Thread Resurrection, Batman!😆
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
electric, heater, hot water, suburban, water, water heater
