10-24-2013, 07:57 AM
#21
08-07-2014, 08:01 PM
#22
Water Heater Switch?
I have a 2012 Puma TT 23-FB. It has a Surburban water heater.
I do not know the model number because the mfg. but sealant over
the numbers. This WH does not have a switch on the outside panel.
I have seen where should be (lower left hand corner) I have looked
all over this panel. No switch. Does it even have an outside switch?
Please help.
08-07-2014, 08:14 PM
#23
Please help.
Without the model number the only way to know for sure would be for you to post a picture the water heater.
08-07-2014, 08:15 PM
#24
Plain Old Member
Here's what I did with mine:
Water Heater Switch Mod - My Photo Gallery
Made the receptacle that the water heater is plugged into a switched receptacle and installed the on / off switch in the hall by the bathroom. Leave the switch on the water heater in the "On" position and operated from the wall switch. Problem solved.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
08-07-2014, 08:21 PM
#25
Lots of early 2000 TT's have only manual pilot and no electric. My 2006 Wildwood is one of them
08-08-2014, 11:40 AM
#26
My water heater access is right beside my fresh tank fill and city water connection. Once I fill the tank or hook up city water I ensure the water heater has water by flipping the relief valve and I turn on the switch. I've never thought it was inconvenient. Burning up the element by flipping the wrong switch on the inside panel would be much more inconvenient.
08-11-2014, 04:29 PM
#27
No electrical switch
I did more research the model # is SW6D, gas only. That makes sense
Because there is no switch on the outside panel. Got this info. off a Suburban
website. Does this sound correct?
08-12-2014, 07:19 AM
#28
Plain Old Member
Deacs1, you are correct. Gas only water heater.
Sent by ME
08-12-2014, 07:34 AM
#29
Please help.
Not all water heaters can be used with AC current. Some are DC/Propane only. Without your model number, it is hard to tell.
Does yours look like this?
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
08-12-2014, 07:35 AM
#30
Here is one that is DC/Gas only:
08-12-2014, 08:41 AM
#31
I have the same setup. Being the dumbest member of this board, I didn't know for many months that I even HAD an electric wh capability!!!
Now that I know it's there, it's sort of a minor issue to turn it on. Course, I always forget to, and leave it on propane, but.......as I said...............I ain't real bright.
08-12-2014, 08:52 AM
#32
X2 with BigJohnD. Here is a spec sheet with the different model numbers of Suburbans for future.
2011 Flagstaff 831 RLBSS
08-12-2014, 04:50 PM
#33
No switch
Mine does not have a outside panel AC on/off switch.
It is a 6 gal. Suburban WH so it has to be model# SW6D.
Just bought this TT (2) months ago, I have a lot to learn.
So I will fill the propane tanks and try it out.
Thanks everyone for info.
01-13-2018, 08:51 AM
#34
GB
No Inside HW Switch
I have to side with the original poster on this one. Coming from an Outback which had both gas and electric switches on the inside to a Wildwood which has the gas switch on the inside and the electric switch on the outside, having both switches on the inside was way more convenient. The argument about making things more difficult because a few people forgot to put water in the tank before turning it on doesn't hold water (pun intended). Instead, what happened with me was I had mine at home on shore power to keep the batteries charged and forgot to turn the electric HW switch off (remember it's now outside out of sight behind a cover) and ended up boiling the HW heater dry and burning it out anyway. I would much rather have a lighted rocker switch inside on the control panel so it's easy to see and use.
2015 Ram 2500 SLT 4x4 Cummins
2015 Wildwood 327RES
Pullrite Superglide 16k
01-13-2018, 09:46 AM
#35
... and I have the opposite view. When I break camp and unhook my water hose from my trailer, I'm standing 2 ft. from the water heater and I flip the outside switch to turn OFF the electric heating element. I don't flip the switch in any direction until I hook up my water hose at the next campsite. When I hook up the hose and test for flowing water (by flipping open the pressure relief valve which is outside and also on the heater face), I turn the electric element ON. I've never felt the need to turn my electric element ON/OFF in the middle of a camping trip.
BTW, the OP hasn't logged on to the site in almost 3 years. I guess he resolved all RV questions one way or the other.
01-13-2018, 10:10 AM
#36
Glad you said something Dan. Last time I mentioned an old thread to someone, I got my butt reamed by other posters.
01-13-2018, 10:24 AM
#37
Our last camper being 30A I never saw a need to use the electric side (As the water heater uses so little propane). We needed the electric for other things. But having said that our older campers only had a propane side.......
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
01-13-2018, 10:46 AM
#38
gbrown:
If you want to add your own switch, see post #13 here:
http://www.forestriverforums.com/for...-110742-2.html
2011 Traverse LT, 3.6L, FWD
01-13-2018, 01:25 PM
#39
What I like about my Attwood WH, inside switch and no anode.
Frank
Frank & Brenda
Thor Windsport 27K TST 507 Tire Monitors
2012 Jeep Liberty Limited Jet 4X4, Hopkins TOWD light wiring, Blue Ox baseplate W/Ready Brute Hercules tow bar and Ready brakes
01-13-2018, 03:42 PM
#40
Holy Thread Resurrection, Batman!😆
