Old 05-17-2016, 08:22 PM   #1
Suburban Water Heater Won't Light!
Hi:
The Suburban water heater (SW6D) in our trailer has never given me any trouble until tonight. It is a propane only version with a re-ignitor. It almost seems like I have a gas flow issue as it doesn't even want to light the pilot, let alone the main burner. Both the furnace and the stove are working fine. I tried cycling the gas control through off-pilot-on-pilot-off several times and finally got the main burner lit for a while. I closed the access door and let it run for a while thinking I may have just had a stuck valve but a few minutes later it was off again and the re-ignitor was trying in vain to light the pilot. Any suggestions?
2010 Wildwood XLite 26BHXL
2013 Ram Outdoorsman 5.7l
Ontherock is offline   Reply With Quote
Old 05-17-2016, 08:26 PM   #2
Georgia Rally Coordinator
aceinspp's Avatar
Check and see if pilot tube is plugged. May have had spiders or mud dobbers plug up. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10 gear
Days camped 2017 62
Days camped 2018 67
Days camped 2019 30
Old 05-17-2016, 08:47 PM   #3
Can I use compressed air to just blow around the tip or do I need to remove the pilot tube completely to clean it out?
Old 05-19-2016, 08:23 PM   #4
Update!
Used the air compressor to blow out the gas heating chamber and all seems to be working great now - thanks!
Old 05-19-2016, 08:35 PM   #5
Mr. Dan's Avatar
Good for you, rock! Thanks for reporting back with your solution. That makes us all more knowledgeable.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 55; booked = 20
Old 05-20-2016, 06:25 PM   #6
I had this same issue as it turned out there was still enough hot(warm) water in the tank that the heater apparently felt that there was now need to light. after purging some of the water in the tank it started right up. no problems since.
gickes is offline   Reply With Quote
heater, light, suburban, water, water heater
