Old 06-20-2015, 08:01 PM   #1
geezer with gadgets
757Dave's Avatar
Suburban WH Question
I know that there are many threads about the suburban water heater on this forum, but I am trying to figure out what position the switch needs to be in to be on or off. I see the picture below and I know where the switch is located, I just don't know what is on and what is off!
Name:	Suburban WH Switch.jpg
Sent from my Atari 2600
2011 Sunseeker 3170ds "Ladybug"
2017 Jeep Grand Cherokee TOAD
Days camped 2015: 37; 2016: 66; 2017: 86 2018: 57
757Dave is offline   Reply With Quote
Old 06-20-2015, 08:04 PM   #2
wmtire's Avatar
The switch is in the ON position in the pic you have there.
That's the same pic I use in the tutorial here:
Suburban's electric switch and much more
2011 Flagstaff 831 RLBSS
I hate it when people don't know the difference between ur and u'r!
Old 06-20-2015, 08:06 PM   #3
geezer with gadgets
757Dave's Avatar
Thank you. That helps me a lot!
Old 06-20-2015, 08:12 PM   #4
wmtire's Avatar
You're very welcome. As stated in the tutorial link above, there is sometimes a hairpin cotter pin in the switches that you have to remove in order to turn the switch to the on position. This keeps it from accidentally getting flipped on, as in this pic.
EDIT: I think I will go ahead and add this pic to the tutorial, as it may help.
Old 06-22-2015, 01:08 PM   #5
It should only be on if you have water in the water heater.
eortiz is offline   Reply With Quote
suburban
