Old 09-07-2016, 07:51 PM   #1
Sulphur smell
After we leave our new silverback 37 bh for a couple of day, we returned and the water both hot and cold smells like sulphur . After running the water for a long time the smell decreases but does not disappear. My wife swears its hooked up to the sewer. I washed the camper last week and didn't detect any smell . Any thoughts about where the smell coming from
Thanks Gene
litespan46 is offline   Reply With Quote
Old 09-07-2016, 08:10 PM   #2
crunchman12001's Avatar
Hi,
In hot climates the water system will get funky in just a short time. If I was you, I would drain the hot water tank and low point drains and sanitize the system with bleach.
In the future, if you are not going to use the trailer for a week, drain everything, every time.
2017 Salem Villa Estate 395RET-Coming soon
2015 F-250 FX4 SUPER DUTY 6.2L Gas 4WD SuperCab XL 3.73 rear / 158" WB / 8' bed. Factory anti-sway and brake controller
Old 09-07-2016, 08:58 PM   #3
Toy-aholic
ours does the same, after flushing for a while it goes away.
2005 GMC Sierra 3500 SLT DRW 6.6 D/A FOR SALE
2013 Crusader 335BHS TE FOR SALE
EXGMTech is offline   Reply With Quote
Old 09-07-2016, 09:20 PM   #4
Flybob's Avatar
The extent is dependent on the concentration of the dissolved elements in the water. Drain water heater and water lines before leaving and you should be OK. Fill a glass with the water and let it sit in the RV and you will see what is going on in your water system.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
