Old 04-16-2013, 09:34 AM   #1
summerizing the toilet in my cottage
We will be leaving our rv in Florida over the summer and I am curious to know what I should do with the toilet. The water and electricity will be disconnected. The water in the bowl will evaporate.
What do I do with the seal at the bottom of the bowl?
Patrick45 is offline   Reply With Quote
Old 04-16-2013, 09:35 AM   #2
Fulltime family RVer
Get some RV Antifreeze (normally for winterizing- the pink stuff) and dump enough to cover the seal into the toilet.
Old 04-16-2013, 09:37 AM   #3
X2 The pink stuff will also evaporate, just not as bad as water, so use plenty of it.
Len & Cheri is offline   Reply With Quote
Old 04-16-2013, 09:41 AM   #4
Triguy's Avatar
RV antifreeze with cellophane should work. It does evaporate, but much slower than water.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 04-16-2013, 09:45 AM   #5
I imagine the antifreeze will not stain the toilet....like pour a gallon of the stuff and place cellophane across the top of the toilet?
Old 04-16-2013, 09:53 AM   #6
Triguy's Avatar
I've never noticed any staining, but then I don't use a gallon either. I'd honestly have to check but I doubt its going to stain.
Scott
2012 Shamrock 233S
Old 04-16-2013, 09:58 AM   #7
Triguy's Avatar
By the way, I have never had to summarize, but I think it would also be good for you to do a really good flush of the black tank and then leave some AF down in the tank. You're going to have to buy at least a gallon of the AF anyway so might as well dump the rest down there.
Scott
2012 Shamrock 233S
Old 04-16-2013, 10:00 AM   #8
TURBS's Avatar
DO NOT leave the the toilet lid closed.
Mold can and will grow.
Leave the lid open.
