Old 05-13-2013, 06:52 AM   #1
Surburban SW6DE Hot WT issue, fix, and I have a question
I tried firing up my Surburban SW6DE hot water tank today on gas, the ignitor was clicking but no flame. After a dozen on - off tries, turning the switch on - off, I gave up and came in to search the web, the majority of web posts said likely bad gas valve Went back out, tried another 6 times, still no joy.
I decided to look inside the interior compartment where the HWT tank is mounted, and found this loose green wire, I shoved it back in the plastic connector, turn the tank on and it fired right up, big joy!
QUESTION - what are those round plastic connectors, are they just fancy butt splice connectors, they are stamped 3M?
cheers - ken
2006 Surveyor
kenair is offline   Reply With Quote
Old 05-13-2013, 07:09 AM   #2
KyDan's Avatar
Looks like a cheap way to make a connection.
It -might- be some sort of fuse or current limiter but I really think
it's just a device for connecting 2 wires together.
Just shoving it back in there is temporary fix. I suggest stripping insulation
off both wires about 1/2 inch and then screw on a little plastic wire nut.
Other option is to open the connector if you can and place the wire all the
way inside and then snap the device shut.
Sometimes you can re-use these connectors and sometimes you can't
get them open again.....
Good find!!
Peace!
Dan & Rita D
Blue Ox WD hitch
KyDan is online now   Reply With Quote
Old 05-13-2013, 08:14 AM   #3
WestCoastRV'er's Avatar
I had the same issue. I cleaned and adjusted the igniter for the hot water heater.
2011 2902ss Rockwood Ultralight
2008 Grand Cherokee 3.0L Diesel (255 hp @ 2900 rpm / 430 lb-ft @ 1,400-2,800 rpm)
3P ProPride Hitch
RV Mods
Wandering RV Life
WestCoastRV'er is offline   Reply With Quote
Old 05-13-2013, 08:32 AM   #4
Yes, new connector, but don't use a wire nut. This isn't a house. There's lots of vibration that will make them fall off. For just two wires, I'd suggest a butt-splice (crimp).
Old 05-13-2013, 11:32 AM   #5
Owner/Operator
RodeoGeorge's Avatar
That type connector has a dielectric inside, and when you make the crimp with a pair of pliers the dielectric seals the connection from potential moisture.
They cost more than the round crimp connectors that are normally used by the majority of RV manufacturers, so I'm surprised but glad to see them used.
RodeoGeorge
2013 Rockwood 8289WS
Mods: Central Vac, PI EMS-HW50C, 2025RV, (2) SCS225 Trojans, PD9260, Awning Remotes & LED Lights, Eliminators, External Water Filter,, Intellijacks
2008 RAM 3500 Cab&Chassis Hauler Bed, B&W Companion Hitch
All My Modifications are at this link:
http://www.forestriverforums.com/for...ons-36212.html
RodeoGeorge is offline   Reply With Quote
Old 05-13-2013, 11:56 AM   #6
You can use wire nuts IF you then use electrical tape and start wrapping below the nut and continue past the end and fold it over and wrap back down to below the nut. Seen professional electricians do it all the time and do it myself when I use a wire nut.
Old 05-13-2013, 03:07 PM   #7
KyDan's Avatar
I suggested a wire nut because the average "joe" probably doesn't have butt
splices or special crimping pliers. A wire nut is a pretty common thing and]they
often come in various parts bags for this or that. Also a wire nut if sized correctly and tightened as tight as you can by hand will be unlikely to fall
off. Tape is an excellent addition. A zip tie placed just below the wire nut
will work great to help secure the joint also. If you do have butt splices and crimping pliers for them, that is a vibration resistant connection for sure.
Peace!
Dan & Rita D
Blue Ox WD hitch
