Old 08-24-2010, 08:05 PM   #1
Exclamation Surprise after sanitizing fresh water tank
Spent the weekend sanitizing the fresh water tank with a bleach solution. After 2 flushes of the tank, I closed the drain valve and filled up the tank. The next day, I noticed a small water spot on the ground under the drain valve. Looks like the valve seal has developed a leak maybe due to opening/closing the valve during flushing.
Do I now have to replace the slide valve on the drain? I hoping the leak will eventually stop...
--Ryan
2005 Sierra Sport Toy Hauler - T18SP
'01 F250 Diesel CC LB
agoodhi is offline   Reply With Quote
Old 08-24-2010, 08:27 PM   #2
Drain valves are probably three dollars. Go buy a new one and be done with it.
Old 08-24-2010, 08:30 PM   #3
milzat's Avatar
--Ryan
Looks like it. I don't think it'll stop.
RV fresh water tank drain cock.
milzat is offline   Reply With Quote
Old 08-25-2010, 12:58 PM   #4
$3, not mine. My fresh water tank drain valve is the same type used on the black/gray holding tanks.
--Ryan
Old 08-25-2010, 04:28 PM   #5
Never seen a slide valve used for a fresh water tank drain. Are you sure you are looking at the right valve? Not saying you aren't right, just never seen it, course there a lot of other things I've never seen, like an honest politician.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 08-25-2010, 05:29 PM   #6
old guys's Avatar
I thought mine was leaking one time so I kept tightening the cap until it stopped. Turned out I had just overfilled the tank and it was running from the overflow down to the lowest point which was the drain cap. Real fun came after the next trip when I went to drain the tank again. Never guessed I was turning it that tight. Old Guys
Best loved friend ever!!! (greatly missed)
old guys is offline   Reply With Quote
Old 10-18-2010, 04:31 PM   #7
Bingo! It was just overflow water from the inlet. Tanks are still full and no more leaks.
Anyone know how many drops of bleach for a 60 gallon tank, I should be putting in to keep the water in the tanks free from bacteria? Yes, I keep my tanks filled year round for emergencies/natural diasters.
--Ryan
Old 10-18-2010, 11:17 PM   #8
Are you using city water or well water? City should be chlorinated all ready shouldnt have to add bleach to it .Well water may be a different story,i would think only a tablespoon should help it some and not be to strong, but this is only a guess.Maybe check with local water guys and see what they recommend
2008 8296SS Rockwood Signature Ultralite
2002 Silverado 2500HD extended cab
chevy02 is offline   Reply With Quote
Old 10-19-2010, 06:00 AM   #9
Boyd's Avatar
Pathogens be gone.
Rule of thumb is one cup of bleach for every 60 gallons of water. I haven't been able to find if this is a safe level for drinking water so I just use this measure to sanitize and then drain.
What You Need to Know About RV Fresh Water Systems--Part 2
"If everything seems to be going well, look around, you've obviously overlooked something."
Boyd is offline   Reply With Quote
Old 10-19-2010, 07:47 AM   #10
Herk7769's Avatar
--Ryan
Could this be the galley tank drain? The fresh water drain should be a white spigot with a leaver on top.
HAM CALLSIGN - KC3FFW
