Old 02-02-2015, 01:01 PM   #1
SW6DE water heater burner not lighting.
The burner has stopped lighting. The igniter is functioning but there is no gas delivery.
JStrickland is offline   Reply With Quote
Old 02-02-2015, 01:10 PM   #2
wmtire's Avatar
Easiest thing first:
Do you have propane in your tank(s) and are they open so propane can get to the water heater. The heater will try a few times to ignite then go into lockout mode if it fails to light. You have to turn off the inside switch, then back on to reset the lockout.
Does your furnace work, and/or stove currently....to see if there is a propane delivery problem.
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 02-02-2015, 01:36 PM   #3
Yes all other propane appliances work correctly.
Old 02-02-2015, 01:40 PM   #4
When I turn off/on the inside switch to reset, the igniter comes on the three times. No smell of gas. Not sure if this would be the board or the gas valve. Last week I could feel the gas valve opening/closing during burner operation and causing the flame to go out. Maybe the valve has finally failed.
Old 02-02-2015, 01:56 PM   #5
wmtire's Avatar
That could very well be.
Any chance your battery is low or are you hooked up to shore power. The reason I ask is low 12 volt power can cause it all not to function correctly.
Old 02-02-2015, 02:10 PM   #6
Apologize. Yes I am on shore power.
Old 02-02-2015, 02:19 PM   #7
arpipeliner's Avatar
If you have a multi meter. You should be able to pull the wires up but not off the coils on the valve and see if current is going thru. Both coils have to open at the same time to allow propane thru. One coil working and the other not will stop gas flow.
There are others ways to check the coils too. If no current at the coils while striker is sparking. You have an electric breakdown from the hi stat, switch, or motherboard.
arpipeliner is offline   Reply With Quote
Old 02-02-2015, 02:23 PM   #8
wmtire's Avatar
Page 15 of the following pdf may show you how to test the valve:
http://hometips.me/mar/suburban_wate...ice_manual.pdf
Old 02-02-2015, 03:32 PM   #9
Thank you both. I will borrow a meter and check voltage coming from the board to the valve. I will check the .pdf also.
Old 02-02-2015, 03:45 PM   #10
Wmtire is going the right way. My ways can break it so you can fix it.
heater, light, water, water heater
