Old 05-03-2014, 08:02 AM   #1
Switch for water heater elect mode
We have a new Flagstaff 8528 IBKWS and I feel stupid for not knowing how to turn on the elect supply for the hot water heater. I know there is a switch inside the cover of the water heater which must be on but is there another switch? On the control panel inside the camper there is only one switch which turns on the gas mode. Other campers we owned had two switches side by side, one for gas and one for elect.
jmwisinski is offline   Reply With Quote
Old 05-03-2014, 08:05 AM   #2
TURBS's Avatar
What model and make water heater?
TURBS
Sabre owners united!
Old 05-03-2014, 08:08 AM   #3
TURBS's Avatar
If it's a suburban its in the lower left of wh
Make sure there's water in it by flipping the relief valve.
Normally flagstaff only has one switch and it's outside as you stated.
TURBS
ID:	51486   Click image for larger version
ID:	51487   Click image for larger version
Old 05-03-2014, 08:24 AM   #4
kodiedogs's Avatar
I have the same one, That the only switch you have to turn on...You just have to make sure to shut it off after you unplug or in storage. or not in use..
2005 Toyota Trundra Crew Cab.
2014 FlagStaff 26RLWS
kodiedogs is offline   Reply With Quote
Old 05-03-2014, 08:26 AM   #5
wmtire's Avatar
If you have the Suburban brand, that is a very common question. Here is a post from the FAQ section that explains it in detail.:
Suburban's electric switch and much more
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 05-03-2014, 08:37 AM   #6
TURBS's Avatar
If you're handy you could interrupt the breaker wh hot wire and install a lighted on/off switch next to your breaker panel for an inside switch.
Old 05-03-2014, 08:40 AM   #7
QUOTE=f1100turbo;602522]If you're handy you could interrupt the breaker wh hot wire and install a lighted on/off switch next to your breaker panel for an inside switch.[/QUOTE]
That's for you lazy folks.
BTW, very appropriate avatar. [
Old 05-03-2014, 08:40 AM   #8
LJ_Sha's Avatar
I also have the same heater and that is the only switch. I've burned out 2 heating elements because of forgetting to shut my off. If you burned yours out the cheapest place I found was on Amazon.
2015 Georgetown 351DS
LJ_Sha is offline   Reply With Quote
Old 05-03-2014, 09:02 AM   #9
TURBS's Avatar
BTW, very appropriate avatar. [[/QUOTE]
Doesn't seem lazy to me ?
that avatar is solely for your benefit.
Old 05-03-2014, 09:04 AM   #10
Originally Posted by f1100turbo View Post
...that avatar is solely for your benefit.
Figured as much.
heater, water, water heater, modifications
