Old 09-19-2011, 08:00 PM   #21
backin15's Avatar
Originally Posted by rbarrieau View Post
I have the switch set " ON " witch is OK . Just supprised the heater is not disabled with a wall switch, I think mine is plugged into an outlet.
sure makes trouble shooting the CB a little easier. thanks
The wall switch just turns the propane burner on and off. The tank will still heat off the electric heater if it is on shore power and the rocker switch in the water heater is set to on.
backin15 is offline   Reply With Quote
Old 09-20-2011, 07:14 AM   #22
KyDan's Avatar
Just put a meter in the heater outlet and tried the cb's .
the CONV breaker is the one that kills the outlet.
from what I can tell with the dimming lights -- etc this is not a breaker I should turn off to control my water heater...
Glad you found the source. It stinks that makers go so cheap on these
things! HWH should not be on the converter circuit IMO but there you go.
It's possible they ran the wires for the HWH outlet back to the power center
and put both the converter AC input on the same breaker as the HWH
right there at the breaker.
If that's the case it's an easy fix to add another circuit breaker.
Assuming you have a spare slot in your breaker panel that is.....
Mine are simple plug in breakers and available at most any home center
or well stocked hardware store.
Maybe yours are the same.
Good luck!
Peace!
Dan & Rita D
KyDan is online now   Reply With Quote
Old 09-20-2011, 08:13 AM   #23
rbarrieau's Avatar
I am going to get a power strip with an on/off switch and plug my water heater into it.
this will give me the kill switch I need, and a couple more outlets in my kitchen.
Thanks all for your advise.
Rich + Lori -2006 salem 27BHSS/2004 Avalanche
4:10 rearend - Roxy the puppy when allowed.
41 Days camped in 2011 and counting.
rbarrieau is offline   Reply With Quote
Old 09-22-2011, 06:49 PM   #24
rbarrieau's Avatar
power strip works great! have it labeled "For water heater only ."
just pop cabinet open and hit the switch.
Also labeled a reminder "assure tank is full before activation".
Thanks to all for your imput.
