09-17-2011, 08:32 AM
switch on water hearter
Tried to turn on electric water heater on camper for the first time last night and the switch is frozen solid. (I did pull the pin first) My initial two thoughts are to spray with lube or put the pin back in and forget about it.
Any thoughts
Rich + Lori -2006 salem 27BHSS/2004 Avalanche
4:10 rearend - Roxy the puppy when allowed.
41 Days camped in 2011 and counting.
09-17-2011, 08:42 AM
I think I would try to squirt some WD40 in the switch with the power off.It is alot cheaper to use electric hot water than propane.If that doesn't work it would still be more economical to get a new switch than to keep using propane.
2011 Salem 30kqbss
2013 Ram 2500
2005 Ram 2500
1968 Pontiac Le Mans
09-17-2011, 11:25 AM
The same thing happened to mine once. I figured I may as well try to free it up as it was going to need to be replaced anyway so I sprayed it with some contact cleaner then put a wooden dowel against it and gave it a tap with a hammer. It broke free but didn't break! I sprayed it with some more contact cleaner and flipped it on and off a dozen times and it has worked ever since.
09-17-2011, 03:30 PM
Thanks --
would have been a real pain to replace this switch, it is tucked in there real tight. The break free worked and the switch is moving now.
09-18-2011, 03:11 PM
Mine is stuck in the on position.
I just use the circuit breaker in the power center to control it.
Others have posted theirs is on a circuit with something else so they
don't have that option. Mine is on it's own breaker.
Peace!
Dan & Rita D
09-18-2011, 05:46 PM
The switch has probably seen some water and humidity. The only solution is to replace it if you cannot unseize it with a penetrant. This is just like the switch light that you have on the outside front of the trailer. They dont last. It is a good idea to rock the switch once and a while to make sure it will not seize.
09-18-2011, 07:29 PM
Mine is stuck in the "on" position, also. Looks pretty flimsy, I was afraid it would break, if I forced off. I also use the breaker to operate it.
09-19-2011, 06:34 AM
NorminN.B. It is the best way to operate it from your breaker from now on. I will make sure I leave my switch in the ON position just in case the same happens to me . I have a minilite 2011 and the front light switch already had to be replace because it was seized. As long as you shut off your breaker when you dont need it!!!
09-19-2011, 09:57 AM
PINTO
Be careful with the WD40 and other spray lubricants etc. Some of them are very flamable! If not the chemical itself the propelant can be. I know WD40 is for sure!
PINTO
2011 Fuzion 325
2015 Duramax Diesel
Chevy 3500 LT Dually
09-19-2011, 10:39 AM
I would use elctro contact cleaner, I have seen stuff like WD40 or LPS, carb cleaner, etc. melt/soften plastic parts
09-19-2011, 11:11 AM
Thanks for all the advise.. looks like the CB is the new on/off switch.
I think the only time I have to turn the electric portion of the heater off is when a generator is used . Otherwise is there any reason to turn it off?
09-19-2011, 02:15 PM
IF you were winterized and wanted to charge batteries by plugging in your
RV the hot water heater element would burn out instantly if you left it on.
I try to remember to flip the breaker off any time we're not using the
trailer.
I also occasionally plug in at home via 16 ga extension cord just to top up
batteries. I don't want the HWH coming on for no reason.
Peace!
Dan & Rita D
09-19-2011, 02:24 PM
Thanks great tip
09-19-2011, 03:45 PM
wall switch
Does the water heater switch, on the wall turn off the electric portion of the heater ,or just the propane portion?
09-19-2011, 04:53 PM
The wall switch is just for propane on my trailer; I would think it's probably the same for other trailers.
Wolf Pup T16P owner
"The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine." - Abraham Lincoln
09-19-2011, 05:37 PM
seems dangerous not knowing at a glance that there is a coil on in your water tank.
09-19-2011, 05:57 PM
Circuit breaker HELP.
WOW!! just checked the camper and water is HOT.. wall switch is off.
Now my problem.. No circuit breaker says water heater..
Here is what I got to work with. Please help .
MAIN----30
A/C---20
CONV--15
GEN--15
GFI--15
MICRO--15
09-19-2011, 06:20 PM
You said you got your outside water heater switch un-stuck.
Are you sure it's in the off position??
It could be internally stuck on I suppose.
My water heater actually plugs into a receptacle that's hidden behind the
water heater tank. It's possible that yours is also. If you can access the
back side of your HWH look for an outlet you can un-plug.
Alternative is get someone with a meter who knows how to use it.
Find the voltage at the HWH and then switch off breakers one at a time
until you get the one that shuts off the voltage to the heater.
It's probably time for you to seek professional help unless you have a
knowledgeable friend or neighbor. This is still pretty basic electrical stuff
but sometimes ya just gotta pay the man!
Peace!
Dan & Rita D
09-19-2011, 06:27 PM
plug
I have the switch set " ON " witch is OK . Just supprised the heater is not disabled with a wall switch, I think mine is plugged into an outlet.
sure makes trouble shooting the CB a little easier. thanks
09-19-2011, 07:23 PM
Just put a meter in the heater outlet and tried the cb's .
the CONV breaker is the one that kills the outlet.
from what I can tell with the dimming lights -- etc this is not a breaker I should turn off to control my water heater...
I guess just unplugging it for now is OK - BUT I will have to add a switch in the near future. This Friday We are going Fall camping for the next 6 weeks at jellystone (Fall DAys).
