Old 10-12-2016, 10:14 AM   #1
Pipcoo15's Avatar
Taking out 3250 rl new, cannot get hot water, put switch on from heater , st...
Taped release valve hot water came out , no hot water faucet, propane will not light fuse okey.
Pipcoo15 is offline   Reply With Quote
Old 10-12-2016, 11:11 AM   #2
AquaMan's Avatar
Your water heater is most likely still in bypass mode. There also is probably air in the propane lines. Keep trying and use other propane appliances to help purge the air. If this doesn't help you may have other issues and we'll need more info.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
Old 10-12-2016, 12:21 PM   #3
I agree that the heater valves are in bypass position. Do you know how to change them?
If the water is already hot from the electric element, the gas side may not fire because it isn't calling for heat.
Gotta go campin!
Old 10-13-2016, 09:15 AM   #4
SeaDog's Avatar
X2 what BR said
Retired Navy
2016 Flagstaff 26 FKWS
Old 10-13-2016, 09:54 AM   #5
wmtire's Avatar
See if this thread link below may help about the winterization bypass/crossover valves. This is such a common occurrence that we keep it as a sticky:
http://www.forestriverforums.com/for...st-103381.html
2011 Flagstaff 831 RLBSS
heater, hot water, switch, water
