06-26-2014, 07:14 PM
#61
I hope the wet grass in not from somebody dumping their gray water.
2012 Flagstaff V Lite 30 WRLTS
2005 Dodge Ram 2500 5.7 Mag Hemi 3.72 Rearaxle
Nights camped 2015 = 23
Nights camped 2016 = 25
Nights camped 2017 = 13
Nights camped 2018 = 3
06-26-2014, 07:52 PM
#62
Nah.. it was the hot air colliding with another front causing a storm .
Wybdgrl do let us know how it all shakes out
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
Seasonal
Zelda the campin dog
06-26-2014, 08:09 PM
#63
So, let me see if I read all the posts correctly.
City water line disconnected.
Fresh tank empty.
Pressure released by opening and then closing a faucet.
Lines filled with water including the hot water tank (winterization valves normal)
Pump OFF
Yet the toilet valve leaked water into the bowl and there is water no where else?
Is that right?
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
06-26-2014, 08:13 PM
#64
Fresh tank empty.
Pump OFF
Is that right?
That's the way I understood it from the git go.
06-26-2014, 08:52 PM
#65
So if the camper was put away in the winter (cold antifreeze) and was unwrapped in the heat of the spring, the antifreeze mix in the plumbing could have expanded putting pressure on the fittings and valves.
Now the hot water heater pressure relief is set pretty high;
the water pump one way check valve is pretty solid with pressure on it;
the only other way out is the toilet valve.
I suppose the valve could leak internally a small amount that would go unnoticed over a period of months and add water to the bowl.
I would have to look at the delta in temperature in an enclosed camper and the amount of trapped water in the system to see how much water could have been expelled due to thermal expansion.
Not saying it did; just saying it could.
06-26-2014, 08:57 PM
#66
So if the camper was put away in the winter (cold antifreeze) and was unwrapped in the heat of the spring, the antifreeze mix in the plumbing could have expanded putting pressure on the fittings and valves...
Only thing is, it filled once to within 1" of overflowing and now filled about 1/3. A little much for just water expansion. IMO
06-26-2014, 09:10 PM
#67
Ya sure that's water? Who is hanging around the storage place.
Oops, sorry Youroo. I see you already approached this angle.
#68
Does sound unlikely, I will admit.
I wonder if it was "pink"?
06-26-2014, 09:18 PM
#69
Does sound unlikely, I will admit. I wonder if it was "pink"?
OP said they had just returned from a trip, so I doubt it. IMO, it has to be the water pump being on either by being turned on or a bad switch. OP seems reluctant to de-energize the pump.
06-26-2014, 10:15 PM
#70
If the water pump were left on - either turned on or "stuck" in the on position (or shorted out) AND there was enough water left in the freshwater tank and/or the lines to nearly fill the bowl once and fill it about 1/3 a second time, how was the OP able to relieve the pressure on the system by opening a faucet? Seems to me he would have gotten a steady stream of water...UNLESS HE DID RELIEVE THE PRESSURE WHEN HE STORED THE UNIT, AND INADVERTANTLY HIT THE PUMP SWITCH TO THE "ON" POSITION AS HE WAS BUTTONING UP THE TRAILER.
OR, THE ALWAYS-POSSIBLE - - - POLTERGESITS
Mike and Yvonne
and Sophie, the little white dog
2017 Columbus 320RSC
2021 Chevy Silverado 3500HD DRW 4X4 Duramax
“It's not how old you are, it's how you are old.” ― Jules Renard
"It's not the years...it's the mileage." - Indiana Jones
06-27-2014, 03:47 PM
#71
Well, we haven't used the fresh water tank and periodically check the levels just in case, but we didn't specifically check after the leak yet. Good thought, though.
Jackie, Paul & Zyriah
06-27-2014, 04:01 PM
#72
Well, with only one line to the toilet and only 2 ways to get water to the toilet, 1 via city connection and 1 via on board water pump and with the city water connection eliminated, logic tells you there is only 1 way left. THE WATER PUMP.
06-27-2014, 06:20 PM
#73
OC's statement about a joke reminded me of when I was much younger I would sometimes add a bit of water to my neighbors rain gauge that was attached to our common fence. Not sure if he ever figured it out but he did move the gauge, guess he did figure it out.
Joe & Beverly
2014 Ram 2500 CTD, CC, SB
2014 8289WS lifted
06-27-2014, 06:28 PM
#74
If you and a buddy use the same storage and you both have like trailers and there is a possibility that his keys are like yours, does he like practical jokes?
06-27-2014, 07:34 PM
#75
If there is no pressure in the system then by water should not be able to transfer from the HW tank to the toilet. The water would have to be under pressure in order to move unless the WH was higher then the toilet. Just because there is a foot valve the inlet is at the top of the toilet.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
