Old 06-23-2014, 03:38 PM   #1
Tank fills while in storage
We have a 2013 Vibe and seem to have developed a problem that seems odd. We camped a couple weeks ago and drained all the tanks, knowing it would be a couple months before we'd be able to go out again. When we checked on everything this weekend, the toilet was about an inch from overflowing! There is no noticible leak or water draining in, but obviously it's coming from somewhere. We aren't hooked up to any water source and don't have any water in our fresh water tank. The only possibliy we can think of is that it's draining from the water heater - is that even possible?? Any ideas and/or solutions?
Thanks!
Jackie, Paul & Zyriah
Wybdgrl is offline   Reply With Quote
Old 06-23-2014, 03:48 PM   #2
Sounds like 2 things are happening. 1. Water pump left on. 2. Toilet valve is leaking.
Old 06-23-2014, 04:32 PM   #3
fonzie's Avatar
If it's in storage and not hook up to any water supply, then I would check the roof vent stack for the black tank and see if cover is on or off. If missing, could have filled during rain storm.
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 06-23-2014, 04:39 PM   #4
Would have taken quite a storm to fill the tank clear up into the toilet bowl through a 1-1/2" pipe.
Old 06-23-2014, 04:41 PM   #5
fonzie's Avatar
OK multiple rain storms........
Fonzie
Old 06-23-2014, 04:43 PM   #6
Like what Noah dealt with? Just ribbing ya fonzie!
Old 06-23-2014, 04:48 PM   #7
fonzie's Avatar
So now you have a choice of post #2 or post #3 or someone played a joke on you and filled your black tank using your black tank flusher......
Fonzie
Old 06-23-2014, 05:09 PM   #8
Oakman's Avatar
Thanks!
Just to clarify, is it your black tank filling or just the toilet bowl?
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 06-23-2014, 05:12 PM   #9
SKnight's Avatar
Could be residual system pressure leaking by the valve filling up the bowl, if your pump isn't left on that is.
Old 06-23-2014, 05:14 PM   #10
fonzie's Avatar
You're probably right and it is only the toilet bowl, I read too much into it....
Refer back to post #2
Fonzie
storage, tank
