Old 03-30-2015, 07:14 PM   #1
V-Lite Fun's Avatar
Tank flush question
I have a Forest River Flagstaff V Lite TT. I have 3 water connections on the driver side of the trailer. The top one is labeled City Water. The two below it say nothing. The owners manual doesn't mention these connections. I assume they are tank flush connections. My question is which is which? There is a sticker off to the side that says Antifreeze but it is not next to one of these. So if they are tank flushes, which one would be for gray and black?
V-Lite Fun is offline   Reply With Quote
Old 03-30-2015, 07:16 PM   #2
fonzie's Avatar
Pictures always good if you have........
Fonzie
Old 03-31-2015, 06:15 AM   #3
bubbles's Avatar
I believe one is for your fresh water holding tank fill and the other one would be for the black tank clean out. Grey tanks normally do not have a cleanout. If you have another holding tank fill access then I'm wrong about that but the grey tank input holds true.
Old 03-31-2015, 06:31 AM   #4
I am taking a WAG but I doubt that a (Threaded Connection) would be for (Fresh water Tank). Youroo!!
youroo is online now   Reply With Quote
Old 03-31-2015, 06:42 AM   #5
Here is a picture of the connections on my 2014 Flagstaff V-Lite 30WTBS. Sorry its not the best, but its one I had from making an instruction sheet on satellite TV setup. The water connection in the upper left is the city water inlet. The connection under the cable inlet is for pumping antifreeze and the one below that is the black tank flush.
bwbarnes is offline   Reply With Quote
Old 03-31-2015, 06:46 AM   #6
bubbles's Avatar
Not a WAG. Mine is and I know some types of trailers have gravity fill (thought this one might not) but have never seen a MH that doesn't have threaded connection for holding tank fill. Doesn't mean it don't exist, Just that I haven't seen it.
Old 03-31-2015, 10:15 AM   #7
V-Lite Fun's Avatar
What you show in your photo is what I have. Thank you for the explanation. The antifreeze sticker is not really located next to one of these connections, hence the confusion. I was surprised the owners manual didn't cover this. Thank you for the reply.
tank
