Old 12-10-2017, 10:46 AM   #1
Tank heaters
My Flagstaff has a switch for tank heater. Which tank (or tanks) does it heat?
Pmccullers is offline   Reply With Quote
Old 12-10-2017, 11:06 AM   #2
On my Flagstaff the single switch is wired to control all the tank heaters.
2001 Ford F250 7.3l converted to F350 specs
2014 Flagstaff 8528RKWS
2 - 2006 model year Border Collies
Mtelkman is offline   Reply With Quote
Old 12-10-2017, 11:27 AM   #3
On our V-Lite 1 switch controls all 4 tanks "F/W, 2 Gray, and Black" light stays On when heaters are On! There is Always a Little water in every tank,just the way it is! Youroo!!
Old 12-10-2017, 11:47 AM   #4
Thanks for the reply. One last point. I read that once I turn on the tank heater switch, there is a thermostat the will turn the heat off an on at certain temps. Sounds like I could leave the switch on during freezing outside temps and basically forget it.
Old 12-10-2017, 11:47 AM   #5
Thanks.
Old 12-10-2017, 12:25 PM   #6
Yes! Youroo!!
heater, tank
