Old 11-15-2018, 09:11 AM   #1
Tank heaters
We haven't had these nice gadgets on previous TT's. Tank heating pads, that is. My question is how well do they work and will they keep the water from freezing at the dump valves.
2019 Rockwood 8332BS Signature Ultra Lite
2018 Chevy 2500HD Duramax 4X4
jimla is offline   Reply With Quote
Old 11-16-2018, 09:30 AM   #2
Herk7769's Avatar
They work great, is the short answer.
They are 12 volt so they will work on battery, but pull some juice so you best be plugged in when using them.
They cycle on and off as needed to keep the LIQUID in the tank at a safe, no freezing, temperature. NEVER use them on a dry tank as they will run all the time and not cycle as designed; shortening their life.
If you have exposed elbows, there should be a pad there to keep the liquid in the fitting warm enough not to freeze.
Name:	Horst Probe Install 006.jpg
HAM CALLSIGN - KC3FFW
heater, tank
