Old 04-09-2018, 03:18 AM   #1
Tank Level Monitoring
need help I just got a 2010 Forest River trailer and when I and when I try to fill the tanks with water it doesn't show that it's filling at all when I look on the panel what am I doing wrong here please help
Kcleggett82 is offline   Reply With Quote
Old 04-09-2018, 08:02 AM   #2
SeaDog's Avatar
Welcome to the forum its a great place to get your questions answered. First are you sure you are using the fw fill and not the city water connection. If your hose screws into the connection it is the city water and not the fw. Look for a cap that removes to reveal a fill tube that you have to hold the water hose to (no screw on connection) Let the forum know what you find even if its silly that is how we all learn.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 04-09-2018, 12:26 PM   #3
They are "BOTH" screw on connections though so now what do I do...??
Old 04-09-2018, 12:32 PM   #4
Prime Member
Connect your hose and turn on the water. Go inside and turn on one of your faucets. If water flows out and the water pump is off, you've got the hose connected to your city water.
Temporarily Camper-Less
2013 Chevy Silverado 2500HD LTZ 6.6L V8 Duramax
Forever in my memory. Forever in my heart.
Laurie J. Wood 3/22/67 - 8/23/19
timfromma is offline   Reply With Quote
Old 04-09-2018, 01:07 PM   #5
MillMitch's Avatar
do you know what model your trailer is? or can you post a pic of the hose connections? that would help people with an answer. Unfortunately, my only screw in hose connections are city water and black tank flush, my fresh is a hose insert as noted above- so I'm not sure where else to tell you to look.
Mitch in MN
2018 Patriot (Grey Wolf) 23MK travel trailer
2011 Durango 5.7L and OEM tow package
MillMitch is offline   Reply With Quote
Old 04-09-2018, 01:15 PM   #6
Flybob's Avatar
Do you hear water flowing into the trailer? The fills should be marked with a label on the TT. One should be fresh water fill and one city water. Note you may also have a screw on connection for a black tank flush labeled.
Suggest you add your TV and TT model to your sig line. It will assist in answering questions such as this.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
