Old 05-11-2014, 05:19 PM   #11
Herk7769's Avatar
The longer the better.
Those enzymes and bacterial need time to eat and dissolve any caked on crud.
Just Flush strongly after you dump.
HAM CALLSIGN - KC3FFW
Old 05-14-2014, 07:12 PM   #12
My question is what's the white wire for and what's the red wire for and where do they go
wminshew is offline   Reply With Quote
Old 05-14-2014, 07:39 PM   #13
VinceU's Avatar
White is ground or common near bottom of tank, Red is "Full" indicator at top of tank
Old 05-15-2014, 06:01 AM   #14
Herk7769's Avatar
Here is the complete wiring diagram.
Not sure which wires you are talking about.
File Type: pdf KIB Monitor Panel M21 Wireing Diagram.pdf (51.2 KB, 24 views)
Old 05-15-2014, 09:44 PM   #15
Whiteknight's Avatar
Could it be the little red module/wire harness that the probes connect to and send the info back to the monitor panel could be bad?
2012 Flagstaff V-Lite 30WFKSS
2015 Ram 2500 Big Horn Mega Cab 4X4
Whiteknight is offline   Reply With Quote
Old 05-16-2014, 09:44 AM   #16
Herk7769's Avatar
The resistor pack is very easy to check (see values in the attached troubleshooting guide). These are normally very reliable and I don't think it is the trouble in this case.
File Type: pdf Micro Monitor Panel Troubleshooting.pdf (149.2 KB, 18 views)
tank
