Old 08-17-2014, 08:14 AM   #11
Evereddie's Avatar
Originally Posted by realebill View Post
if you are trying to prevent corrosion with standard rtv,you will be fighting a losing battle. ordinary rtv when curing emits acedic acid which in itself is corrosive.to prevent this,alcohol cure rtv is available. 2 of the products are Dow Corning 3145 and G.E.162.this type of rtv should be used on any electronic application.
AnaLog Services RTV Silicones
Yes, good point. After years of owning a boat (in a past life) I used a liquid tape product for many electrical connections I wanted to seal up and will use that when I am ready to seal up the sensors. This stuff. BUT,...I may choose to upgrade the sensors to the ones Herk talked about if so motivated.
EDIT: Ha, by the time I finished posting and cleaning up my grammatical mistakes Herk beat me to it. But ya, liquid tape has worked for me.
Evereddie is offline   Reply With Quote
Old 08-17-2014, 08:47 AM   #12
Tank sensor errors - I discovered something. Theory.
Done marina electrical wiring for 25 years, been using Scotchkote. Best I have found. Available at Home Depot.
http://www.3m.com/product/informatio...l-Coating.html
Started Out With Nothing,
Still Have Most Of It Left!
jwedell is offline   Reply With Quote
Old 08-17-2014, 09:01 AM   #13
Evereddie's Avatar
Scotchkote Electrical Coating :3M US
Yes, used that too and probably more than the one in the link I posted. Yes, good stuff indeed.
cover, tank
