Old 08-16-2012, 03:01 AM   #31
2Susan's Avatar
Originally Posted by f1100turbo View Post
how does this work ?
You put the paper in waste basket. We use unscented diaper wipes - they go into the waste basket. No paper hanging on probes that way. Waste basket is lined with one of those ever present grocery store plastic bags, emptied when full (or if I am taking out other trash). No odor from what is in the wastebasket.
2Susan is offline   Reply With Quote
Old 08-16-2012, 06:28 AM   #32
Herk7769's Avatar
Originally Posted by Blakew76 View Post
The black tank level read "E" even though it definitly wasn't after a weekend of dry camping. When we got to the Sani dump about 1/2 hour later, it was reading 2/3. I talked to the dealer about it, they said there was possibly something covering the sensor & driving down the road removed what was covering it. They also mentioned the ice in the tank thing too.
Your dealer is not correct. "E" means there is no ground path AT ALL.
The only time you will see an "E," with water in the tank, is a loose or broken wire on the ground probe, or a failure in the MicroMonitor PC board.
My money is on a bad connection at the white wire (ground probe).
This will happen again and I would have them check the sensor wires for a lose connection at the tank or in the crimp hat that holds all the white sensor wires.
They won't want to because it is a PITA to drop the belly covering just to check for a loose wire. They may also charge you for the labor if they "CND" it. (Could Not Duplicate)
File Type: pdf Micro Monitor Panel Troubleshooting.pdf (149.2 KB, 11 views)
HAM CALLSIGN - KC3FFW
Old 08-16-2012, 02:22 PM   #33
I thought about it after, it should read full if there's something covering the sensors, not the other way around. I'll look for a connection, if it's nothing obvious, they can look at it, (still under warranty).
2007 Dodge Ram 1500, 2012 22 ft Wildwood X-Lite TT
Blakew76 is offline   Reply With Quote
Old 08-16-2012, 02:25 PM   #34
Herk7769's Avatar
There is a crimp "hat" where the white wires from both tank ground probes join with the white ground wire from the monitor. If that crimp is bad or corroded you will start having "E" indication problems.
Old 08-21-2012, 07:47 PM   #35
Thanks for the info, I'll have a look
