Old 07-06-2014, 11:43 PM   #21
asquared's Avatar
Are you sure it's not the battery off gassing ?
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 07-07-2014, 12:53 AM   #22
Yes, I'm sure. The battery is out front in its own box.
wantahertzdonut is offline   Reply With Quote
Old 07-07-2014, 01:16 AM   #23
asquared's Avatar
The reAson I ask is when they off gas it gives off that sulfur smell.
2014 Sabre 34REQS-6
Old 07-07-2014, 01:21 AM   #24
Gotcha. The battery is nowhere near the a/c or tanks on my trailer, and its shut off now too. But the smell does match up with what you're saying.
Looks like I'll be doing some intensive searching on this thing.
Old 07-26-2014, 06:14 PM   #25
We've been getting by leaving the gray tank valve open. I bought a knockoff flush king and have been using that to wash the hose after dumping the black tank. Replacing the air introduction valve in the kitchen didn't solve the problem.
We did fill the gray tank to capacity, as I forgot once to open the gray tank valve after dumping the black. Water backed up into the pipes, which called attention to a leak at the P trap under the kitchen sink. The flange that mates to the second end of the P trap was cracked. After cutting the old pipe out (thanks FR assembly workers for forgetting to use a screw-in piece ) and getting an adapter to use standard off the shelf stuff, it was fixed. Haven't had a smell yet, but I'm not holding my breath. I'll keep you all posted if this cures the smell.
Old 08-02-2014, 07:10 PM   #26
We still got the smell but it wasn't as bad.
We've changed locales and are no longer getting the smell. We haven't been running the a/c where we're at and no smell. I'll try the a/c shortly but I think the tank just needed a good cleaning out which it got on the drive. Plus not being in the extreme heat of Phoenix helps too.
tank
