Old 06-11-2011, 06:25 AM   #1
Jorman's Avatar
Tank Values
Why does the black tank have 2 values?
2007 Sierra 301 BHD
2008 Ford F-250 XLT CC 6.4L PS
My goal in life is to be as good a person as my dog already thinks I am.
Jorman is offline   Reply With Quote
Old 06-11-2011, 06:57 AM   #2
MtnGuy's Avatar
A photo would be good. My rig only has 1 valve.
You sure 1 of those valves doesn't go to your gray tank ??
Old 06-11-2011, 10:21 AM   #3
You have a 54 gallon grey tank which should be for galley and shower. You have a 30 gallon black tank which should be for poo. (Sometimes Forest River has the bathroom sink going in the black tank, not sure about yours.)
Since you have two valves, one is black, the other grey.
Hope this helps.
Jack
PS, your fresh water tank is 48 gallons.
2006 Flagstaff 831RLSS Travel Trailer
2007 Chevy 2500HD 'Classic' with the Duramax engine.
Converting a 1956 GMC PD4501 Scenicruiser, ex Greyhound into a motor home.
jackhartjr is offline   Reply With Quote
Old 06-11-2011, 11:03 AM   #4
Jorman's Avatar
I have a valve for grey and 1 for black and also one underneath on the black side. I tried to upload a photo from my phone but it wouldn't go. I'll try again later.
2007 Sierra 301 BHD
Old 06-11-2011, 11:29 AM   #5
49 year camping veteran
Maxterra's Avatar
My other forest river trailer (sandpiper) had two valves inline on the black tank, which I thought was a great idea for redundancy.
Have seen a few times the black valve leaking on other rigs.
Maxterra is offline   Reply With Quote
Old 06-13-2011, 10:10 AM   #6
Jorman's Avatar
What is the small valve on the left?
Name:	Tank Valves.jpg
2007 Sierra 301 BHD
Old 06-13-2011, 11:15 AM   #7
camper_Lucy's Avatar
General rule, gray handle is for a gray tank. On our Sierra we have 3 gray tanks and 2 black, by draining one and checking the monitor, then the other you should be able to determine the tank to monitor number. One is most likely the bath, the other is most likely the galley. The tanks are usually in the general proximity of the service area so looking at there location or the general plumbing direction if you have an enclosed bottom should give you a general idea of which one is which.
2011 GMC 3500HD 4x4 Crew DRW Duramax
Pullrite 20.5K
2012 Sierra 365SAQ
2006 Police Roadking FLHPi
camper_Lucy is offline   Reply With Quote
Old 06-13-2011, 03:34 PM   #8
MtnGuy's Avatar
I agree with camper_Lucy. The 2 small lines on either side are probably grey tanks, and the big line in the middle is probably the black tank. I don't see a valve on the black tank, though.
Old 06-13-2011, 03:56 PM   #9
MrT
MrT's Avatar
We have 3 tanks, black, grey & galley. The black & grey (shower & lav sink) tanks have separate valves but share a common outlet. The galley tank is a separate valve/outlet. The black/grey outlet is easily accessible (ahead of the axles on the road side) at all times, but the galley outlet (behind the axles on the road side) is a bit of a challenge with the slide extended.
2017 Cedar Creek 38CK Hathaway Edition
2015 Ford F-350 6.7 CC 4x4
B&W RVK3300
Full-timing since 5/2/2016. Roam Sweet Home.
FROG Int'l Rallies: 2012-2017
MrT is offline   Reply With Quote
