Old 03-19-2014, 11:37 AM   #1
jonrjen's Avatar
Tankless hot water heater, it's a good thing.
I see more post of owners complaining about the Garrad Tankless Water Heater. But, we just spent our first night out in the new Wildcat and really enjoy the almost instant endless supply of hot water.
Yes, it comes with a learning curve and yes the instructions of it's use is not the best of written directions, but if you take the time to talk to others who are knowledgeable of how the system is designed to work it is a great feature to have. It does take alittle getting used to from the sound it makes as it fires up and runs.
I do know one feature that should come with the tankless water heater, that is a larger grey water tank.
2018 Berkshire XL 40B
Past RVs: National Pacifica 40', Kenworth T300 Toterhome, Jayco Class C 32'. American Eagle 40',
American Eagle 40', Bounder 38' tag axle
jonrjen is offline   Reply With Quote
Old 03-19-2014, 11:53 AM   #2
tank less water heater
we recently bought a 2008 wildcat and immediately had to repair h20 pop off valve. I was wondering about replacing the h20 tank with a tankless h20
can you go into more detail how it works.
I need knowledge to make a wise choice
thank you
kimmccormick is offline   Reply With Quote
Old 03-19-2014, 12:28 PM   #3
Kaadk's Avatar
Brother-in-law's got the tankless in his wildcat. We've debated the pros and cons between his setup and the Suburban in mine. Basically they boiled down to:
Tankless:Pro: Never run out of hot water
Con: Only runs on Propane
Tanked:Pro: Can run on electric and save propane
Con: Possible to run out of hot water.
Depends what matters to what people.
Old 03-19-2014, 12:34 PM   #4
EricInColorado's Avatar
No electric on a tankless???? That would kill it for me. When on shore power, I love my hot water. But when on propane, it is fired up very sparingly. And then we use the hot water sparingly as well!
Eric, Tara, and most of China
2013 Camping Nights: 2
2014 Camping nights: 31
TT 2014 Rockwood Roo 183
TV 2012 Nissan Armada
EricInColorado is offline   Reply With Quote
Old 03-19-2014, 12:35 PM   #5
Kaadk's Avatar
I don't know if some models have it, but I can say for certain his does not.
Though, a tankless on propane is more fuel efficient than a tanked on propane. So if you don't have shore power the tankless is the better approach.
Old 03-19-2014, 08:37 PM   #6
jonrjen's Avatar
Sorry for the delay in getting back to this post, but I have been in the shower with unlimited hot water all day....LOL, just kidding.
IN the past we were also one of those Rv'ers who like leaving the water heater on electric and letting the camp ground pay the bill, but we are really liking this endless hot water system. You just got to make sure there is no air in the water lines, that you have a good steady flow of water and the water pressure stays constant.
It take a little getting used to adjusting the temp of the hot water by control of the flow of the hot water volume and not by blending cold water in to the mix.
Old 03-20-2014, 10:39 AM   #7
It is much harder to heat water in a tankless system with electricy. The propane does a much better job. That is why we have a tank system. We don't turn it on until we need hot water and turn it off when we are done. I mostly shower at RV park bath houses but my better half only uses the shower in our fiver.
whj77372 is offline   Reply With Quote
Old 03-20-2014, 10:43 AM   #8
Fulltime family RVer
I read this often- how much propane does the water heater really use? We've ran ours on both and haven't seen any kind of noticeable usage until we start to fire up the furnace and then we use it like (insert witty analogy here).
Old 03-20-2014, 11:09 AM   #9
Kaadk's Avatar
Let's put it this way:
- I picked up the TT in April,
- Ran WH on propane only for any trip between April and August, when I got the WH electric switch fixed.
- Ran the fridge on propane for all stocking and travel, only switched to elect when at the site
- Used the Sidekick about 2x a day, Stove about 1x a day for cooking meals.
- Finally ran through my first 20lb tank near the end of September, after turning the furnace on.
Note, that usage pattern was over ~20 nights camping. All in all, I'd have to say the suburban is not propane crazy.
Still, it would be nice to see a tanked/tankless hybrid, where the tank is heated by electric and supplemented by a propane ondemand approach like the tankless. This should be doable. Since a tankless works on a delta approach, if the water's already hot the tankless won't need to kick on and heat the water further, but if it's not, (like if without electric) then it could do the job. Just a matter of turning off the propane side of a suburban and then putting the tankless system downstream from there.
Old 03-20-2014, 11:30 AM   #10
The geek in my thinks designing the hybrid unit is a fun Thermodynamics problem. (Sad thing is, I'm fascinated by thermodynamics, but never took the class while getting my BS in Civil E. That was dumb.)
heater, hot water, tank, water, water heater
