Old 10-16-2018, 06:04 PM   #1
Taps open, or closed?
When winterizing with antifreeze, after it comes out of every tap, do you close or leave them open??
Kuba is offline   Reply With Quote
Old 10-16-2018, 06:06 PM   #2
Open.
Don’t forget the outside shower.
Bob
HappyTrav is offline   Reply With Quote
Old 10-16-2018, 07:06 PM   #3
My trailer is seasonal, I never used fresh tank. Used the pump to pump antifreeze. What about my city connection? Should I pour some antifreeze into it from outside? I did drain my low points
Old 10-16-2018, 07:13 PM   #4
Just as confused as you
Scrapper's Avatar
I leave mine closed after bleeding off the pressure.
With AF in your system, the WP running, and the FW hose disconnected, look in the FW connection, you will see a check valve, push the check valve with your pinky finger or something similar. Oh, and stand to the side or you will get pinked.
Richard & Jill
Camping since 1989, seasonal since 2000
