Originally Posted by LindaNTom
I have a 2016 Cedar Creek 34RL. After our last trip the black tank cable handle will not move. I checked underneath and the the valve works its the cbale that is the problem. I heard that Valterra has a solid cable which is better than the Bristol wound cable. My question is will the Valterra cable work on a Bristol valve and has anyone done this, or should I stick with a Bristol Cable.
Thanks in Advance
It's not a problem, you can order the Valterra cable from places like amazon and the cut it to fit. You'll need to take the belly apart and try not to take the valve off.
It's a pretty good amount of work but I love the new setup.
You might as well fix all of them while you're there.
