Old 10-28-2018, 12:23 PM   #1
Chardagha's Avatar
Thermocouple in Suburban water heater?
Good day, I have a 2004 Wildcat 5th wheel and the water heater is not working. I can reset the switch at the heater panel and the gas will ignite, but not reignite after it shuts off. I suspect a thermocouple problem but cannot seem to find it when I inspect my heater. Also, I cannot de it addressed in any manual. Who can tell me where to find it?
Chardagha is offline   Reply With Quote
Old 10-30-2018, 05:38 PM   #2
Chardagha's Avatar
Well, apparently it is I who shall educate this forum. After receiving no responses, I went to an RV repair facility and had an eye opening conversation with a knowledgeable tech.
The Suburban SW- series is a direct ignition water heater and does not use a thermocouple; instead, it uses resettable high- and low- limiter switches.
Now I will test and probably replace said switches.
Old 10-31-2018, 10:36 AM   #3
Head Rambler
Sorry I didn't see this earlier, but glad you got good advice.
There is also a control board on the 12 volt side, and that could be your problem. Testing the Hi-Limit & T-Stat switches is the easiest thing to do, and I recommend that to begin with.
Gotta go campin!
Old 10-31-2018, 10:54 AM   #4
wmtire's Avatar
Suburbans have a hi-limit/ECO (Emergency Cut Off) thermostat and an operating thermostat...that come together as an assembly, and are mounted up against the tank wall.
If your heater also has an electric heating element, it has a separate thermostat assembly for that to.
Suburbans also have a flame sensor, that detects the flame or if will shut off the heating source via the control module board.
We keep a troubleshooting/service file for these in our library here on FRF.
Forest River Forums - Downloads - Plumbing, Propane and Water Systems
2011 Flagstaff 831 RLBSS
As I've told my kids a hundred zillion times, "Don't exaggerate."
Old 10-31-2018, 10:57 AM   #5
wmtire's Avatar
This recent thread may help also, as I went into some detail on troubleshooting it.
Gas/Electric water heater issues.
heater, suburban, water, water heater
