Old 03-14-2015, 06:47 PM   #11
Brother Les's Avatar
Originally Posted by OldCoot View Post
A pc of crud from the water lines probably holding the valve open. Just take the valve apart and clean and lube thoroughly with a silicone paste like Danco.
Never did quite figure out how to get the step on flush valve off or apart.
Did not want to break the foot flush handle by trying to pry it off. Ended up reverse flushing the valve system and what ever was in there must of been flushed out. It now holds the water system pressure fine and is not flowing.
Still would like a diagram on how to take this apart for the time that I really need too.
The stool unit is a:
Thetford: Model 42072
Style II High
Bone Tray
It is fixed, but.....
any vid on this model?
Thanks...
Brother Les
Old 03-14-2015, 07:00 PM   #12
If it is this style, the pedal just snaps off. It is scary taking it off, I watched a tech do it twice before I did it. He replaced the valve and didn't get something right, came out to the trailer and re-assembled it and about a month later it started leaking again. I then took it apart and applied a liberal amount of Danco all over it and it's worked flawlessly for 2 years.
Aqua Magic Style II
Old 03-14-2015, 08:03 PM   #13
Batts-toy's Avatar
I have worked on a couple of these but they had the valve and petal on the opposite side and everything was held together with screws.
Dale & Terri, Lulu & Tiki (our Chihuahua's), New rescue puppy Prince - Pom/Pug mix.
2013 Tundra, Double Cab, 5.7, TRD Off-Road, 4X4, Full Tow Package
2013 Wildwood T26TBSS - Sold
2000 Gulf Stream Sun Voyager M-8357 MH, Ford Trident V10 Gasser, 35 foot.
Batts-toy is offline   Reply With Quote
Old 03-14-2015, 08:15 PM   #14
The Thedford I listed is definitely not attached with screws, it just snaps off.
Old 03-14-2015, 09:09 PM   #15
Aqua Magic Style II
Yep, this is it. The foot just pushes into the side? Did you work the pedal off back and forth or slid something behind it and pried it off. Do the inner parts work out to or is something holding them in? Part #9 looks to be the water valve that would leak. I was concerned about trying to take it apart and just back flushed it with the valve open and I assume I washed what ever was in there away.
Style II Parts
Found this video
https://video.search.yahoo.com/video...t=mozilla&tt=b
Thank- again. this is the visual of what I needed.
Brother Les
ford
