Old 03-14-2015, 01:23 PM   #1
Brother Les's Avatar
Thetford stool will not shut off????
I am now de-winterizing my unit and put water in the tanks. I turned on the water pump to flush the lines and the stool is running water like mad. What is going on here? I winterized everything. How do I take this apart to see what my be wrong/sticking open? The foot pedal seems to 'work' but it does not stop the flow of water.
Help...
Brother Les
Old 03-14-2015, 01:43 PM   #2
A pc of crud from the water lines probably holding the valve open. Just take the valve apart and clean and lube thoroughly with a silicone paste like Danco.
Old 03-14-2015, 01:50 PM   #3
Batts-toy's Avatar
Help...
Brother-Les, the valve is at the end of the foot petal under the cover at the bottom of the stool unit. If you get down low you should see one or two screws to take the cover off and then some more screws to take the valve assembly off/apart. Some unit do have snap on covers instead of screws depending on your model.
Dale & Terri, Lulu & Tiki (our Chihuahua's), New rescue puppy Prince - Pom/Pug mix.
2013 Tundra, Double Cab, 5.7, TRD Off-Road, 4X4, Full Tow Package
2013 Wildwood T26TBSS - Sold
2000 Gulf Stream Sun Voyager M-8357 MH, Ford Trident V10 Gasser, 35 foot.
Batts-toy is offline   Reply With Quote
Old 03-14-2015, 02:00 PM   #4
Thanks guys, I will look into taking it off and cleaning it out. Lube with a silicone such as Danco....
Thank-you Batt-toys for giving a heads up on what to look for.
All of the parts to take off are on the lower right side connected to the pedal and not in the back. It does not sound like i would need to pull the stool. Correct
Thank-you
Brother Les
Old 03-14-2015, 02:08 PM   #5
Just make sure it's a paste, not a spray on.
Old 03-14-2015, 02:18 PM   #6
I pulled the stool (easy). there are no screws that hold any plastic on. do I 'pull' the foot lever cover off and how do I do that with out breaking it?
Brother Les
Old 03-14-2015, 02:21 PM   #7
coupevillefish's Avatar
Also check the spring. Ours was running (overflowed) and I found that the cap on the spring had loosened and did not have enough tension to close the valve. I discovered that while trying to install the wrong new valve that CW sold me.
coupevillefish is online now   Reply With Quote
Old 03-14-2015, 02:22 PM   #8
Do I take the two bolts out of the top back the hold the bowl to the pedestal?
Brother Les
Old 03-14-2015, 02:32 PM   #9
I've never heard anyone call a toilet a "stool". I do know that toilets and stools can be used in the same sentence...
2011 F150 SuperCrew 5.0 4x4
2012 Flagstaff 27BESS
pappcam is offline   Reply With Quote
Old 03-14-2015, 05:30 PM   #10
(that is where I do my most reading, hence...I call it the reading room )
Here in Mizzereee/Mizzurah where there is a even combination of Yanks and Johnies, and an even touch of both coasties, there seems to be two or more words for every item. We are the most southern state of the northerners.... the most west of the easterners, the most northern state of the southern states and the most eastern of the west states. The language is very blended. Hillbillies and two of the largest cities in the nation.... 'we' seem to be confused to t-others, but the blending does work.
Blessings to you in Kanuhda
Brother Les
ford
