Old 04-23-2015, 06:30 AM   #1
Thetford toilet bowl doesn't hold water
I have a model. 34060 Thetford toilet with the foot pedal. The bowl will not hold water any more. I assume that the black ring is a seal. Is that easy to repair. Does anyone have any directions for me? Also, is that part common at my local TV dealer? Thanks!,
2019 Salem Villa Estate
395 RET Destination Trailer
Jimh64 is offline   Reply With Quote
Old 04-23-2015, 08:25 AM   #2
PhoneDude 8289's Avatar
Your local dealer may have the correct seals. When I had my Cougar I had the same trouble, bought the seals at Camping World. Toilet came apart real easy, fix was easy, took about an hour.
Joe & Beverly
2014 Ram 2500 CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is offline   Reply With Quote
Old 04-23-2015, 08:33 AM   #3
rattleNsmoke's Avatar
There's a youtube video on RV toilet repair. The author is perty thorough. Check it out.
rattleNsmoke is offline   Reply With Quote
Old 04-23-2015, 07:48 PM   #4
Thanks!
Old 04-24-2015, 09:39 AM   #5
When I first camped in my Sabre 5th wheel the seal came loose and would not hold water. Luckily the seal was on a little ledge before entering the black tank. I was able to retrieve the seal and reinstall. You can do this without taking the commode apart. It is a process of determining the correct position of the seal and working it back into position in the top side of the commode drain. It takes a little trial and error to get it seated. Sometime a little Vaseline helps.
RetCityMan
CityMan is offline   Reply With Quote
Old 04-24-2015, 06:25 PM   #6
Go to the Thetford website, find your toilet, and then look on the schematic and find what you need. It will probably be a ball and seal and everything you need comes in one kit. Then look on EBay and find that kit. It will be cheaper and faster than ordering from Thetford. I ordered a part from Thetford and it took 10-12 days for delivery. I ordered others from EBay; free shipping and got them in @ 3-4 days. These kits will have complete instructions and it is fairly simple. WEAR rubber gloves!!
VMI'62
Edmund is offline   Reply With Quote
Old 04-24-2015, 06:52 PM   #7
Cornelius's Avatar
Another possibility for the toilet bowl not holding water could be a buildup of mineral scale on the gasket. This is caused by minerals such as limestone in the water supply. There are several mineral scale removal products available that can help. I have had very good results with a product called Lime Away. It's available at Dollar Tree stores.
2010 Georgetown 373
2013 Jeep Wrangler
Cornelius is offline   Reply With Quote
Old 04-24-2015, 07:54 PM   #8
Thanks for all the advice. I am wondering if it was the mineral build up or just dried out over the winter, because now it seems to be holding some water again after several uses.
Old 04-24-2015, 07:55 PM   #9
LittleHome's Avatar
Littlehome
Just replaced the seal on my style magic plus last weekend. I purchased the replacement seal on Amazon $18.00. Job was not hard but It did take about three hours, but the toilet looks like new after replacing all the tubing and cleaned everything.
We will see if the new seal last for five years like the original.
Steve and Jeannie
2010 Rockwood 8314BSS
2007 Ford F250 Super Duty Crew Cab 4x4
Erlanger, Kentucky
LittleHome is offline   Reply With Quote
Old 04-25-2015, 06:48 AM   #10
nikita's Avatar
Our old 5er Cougar did the same thing. We were told by a fellow camper that if you call Thetford on the phone they will send you a seal in the mail for free. We did and they did!! Easy Peasy
Nikita
2020 Chevy Silverado Diesel 2500HD
2015 Sabre 33 RETS 5th Wheel
nikita is offline   Reply With Quote
Old 04-27-2015, 02:45 PM   #11
pappy's Avatar
toilet seal
mine kept leaking out. found out my wife was using a toilet brush and pulled the seal loose. i put on rubber glove pushed the seal down. no more leak, and no more brushing up and down by my wife.
pappy is offline   Reply With Quote
Old 04-30-2015, 09:26 PM   #12
No big worry, just stop water going into bowl long enough to smear a little Vaseline onto top and bottom of the black rubber seal and keep water in it for about 3 days. It will start swelling the seal and the Vaseline will help seal it also.
DAPYES is offline   Reply With Quote
Old 04-30-2015, 09:30 PM   #13
Best way we have found to clean it is to spray entire bowl with Tilex and let it sit a few and wipe out with paper towel.
ford, water
