Old 10-16-2015, 05:08 PM   #11
Yes I am sorry spell check got me.
aszmabbott is offline   Reply With Quote
Old 10-17-2015, 01:25 PM   #12
I am assuming you have a rear kitchen model sense you also have an outside kitchen. That valve is for your second grey water tank, for the kitchen. Your first grey water tank is for your bathroom sink and shower. The valve for it would be by the black water valve. You have 4 tanks, one black, two grey an fresh water tank.
Most keep the black and grey next to each other closed while camping. They hook the drain hose up to the kitchen grey water connection and leave that valve open. When ready to leave drain your black tank if it is about half full, flush your black tank if you have a flush system, then drain that grey tank. This allows you to clean your hose out with that grey water tank.
Jim
07 Dodge 1500 crew cab with 20" wheels, 08 Forest River Rockwood Signature Ultra-lite 8280SS
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man."
George Bernard Shaw
oldtool2 is offline   Reply With Quote
Old 10-17-2015, 02:04 PM   #13
Kitchen is in the center, bunkhouse in the rear. The build sheet says one grey, and one black tank both 38 gallon and a 32 gal. Fresh. There is only one dump out connection, how could there be another tank?
Old 10-17-2015, 02:24 PM   #14
My guess is there is a second grey water tank for your kitchen. The 38 gallons could be the combined capacity.
Close all the valves. Run your kitchen water for a little while. Then open that valve and see what happens. If you get water flow then its got to be from a second grey water tank. You say that handle has a cable attached so it could be controlling a valve 20 feet away.
Jim
George Bernard Shaw
Old 10-17-2015, 03:05 PM   #15
I will try that, thanks for the info.
cat
